T3 vs T4 1.06 twinscroll housings, any power/response difference?
Old Jun 4, 2010 | 04:56 PM
Ted B's Avatar
Originally Posted by RSMike
Hello,
My Friend is looking to get a HTA3582R Twinscroll 1.06 turbo in T3 form.
This way he can then switch out to a smaller T3 turbo (3082, 3076) if he wants to for comparison testing etc.
Will the T3 version of the 1.06 housing causing any restriction or power loss compared to the T4 version of the 1.06 housing for the same turbo? (3582).
Mike,
Given my experience at this point (both driving/tuning/testing) with various combinations, these are my observations:
A local car that I know well and have driven is Drifto's HTA3076 2.0L with 1.06 divided T3. With E85, we know it spools like gangbusters, has V8-like response, and it's good for ~570whp with E85:
https://www.evolutionm.net/forums/ev...e85-33psi.html
Regardless of what you are dealing with (e.g. 35R, 3076R, etc.), we know that turbine housing can support enough mass airflow to deliver at least that level of power with appropriate equipment.
As for the 1.06 TS T4, it gives superior spool and transient response characteristics to anything equipped with a 0.63 A/R T3. This is my HTA3582R setup tuned on 98 RON (93 U.S.) with a 1.06 TS T4:
https://www.evolutionm.net/forums/ev...82r-93oct.html (see post #43)
Now, despite the fact that my 2.0L engine is 'hindered' by the largest intake ports possible (literally), large cams, and large tube exhaust primaries, the difference in transient response between my car and any 35R open T3 2.0L car is abundantly clear (and that is putting it mildly).
I managed ~585whp with 93 octane before calling it quits. I haven't finished tuning E85, but it's generating more power.
There is a forum member who demonstrated 766whp through a 1.00 A/R TS T4 and GT4088R, so we know what's possible with respect to mass airflow handling capacity.
The only one of these turbos (AFAIK) that can be used with either divided T3 or T4 housings is a GT35R (although I heard a rumor about a TS T4 3076R housing). The 1.06 TS T4 has a larger internal volume than the equivalent T3, so a logical guess is that it's going to handle a bit more power.
I hope that helps.
Old Jun 4, 2010 | 05:22 PM
RSMike's Avatar
yes that does help, Thanks Ted B
Thanks for your input too Geoff.
Expect some 3076/3082/3582 testing coming up in the future
Old Jun 4, 2010 | 05:26 PM
scorke's Avatar
I have a 1.06 T4 if you are interested for testing, open scroll though.
I went from .82 T3 to 1.06 divided T4 and picked up over 30 ft lbs of tq, Not to mention however much headroom the bigger housing gave me if I were to push it to it's limit.
Scorke
Old Jun 4, 2010 | 05:31 PM
justboosted02's Avatar
Originally Posted by warp9
A 1.06 T4 housing (if they made one)would be terrible on a 4 cyl. I would use a .58 for a T4 back housing or the next size up from that at the most
hmmm, i must be doing something wrong... my TS t4 1.22 A/R turbo makes 20 psi at ~3750 rpm in third
Old Jun 4, 2010 | 05:38 PM
EvoDan2004's Avatar
1.22 for what turbo
Old Jun 4, 2010 | 06:22 PM
Originally Posted by evodan2004
1.22 for what turbo
BWs200sx
Old Jun 4, 2010 | 09:07 PM
redleg225's Avatar
BWs200sx
On a T4TS 1.22 A/R? You sir, have a unique setup. You should post pictures and data.
Old Jun 4, 2010 | 09:14 PM
TTP Engineering's Avatar
Scorke
A graph overlay would be helpful for the members if you have one.
Old Jun 4, 2010 | 09:48 PM
JohnBradley's Avatar
So approx the equivalent of a .74 A/r single. I have a .64 on a 3.0L that spools at 2500, so this seems very believable. I would be interested in seeing some logs with shifts where you lifted to shift and the time back to full boost.
Old Jun 4, 2010 | 10:46 PM
scorke's Avatar
I don't want to have to explain boost logs, camshaft reports, compression tests, octane checks and everything else that comes along with that!
Pump gas, low boost.
If you are doubting twin scroll at this point your saying that a FP Red, Black, BBK, GT40R and larger have no use, for either street machines or all out drag cars. Times change,
now you can do this with twin scroll at more power levels because of the offerings from different manufacturers.
Scorke
Old Jun 5, 2010 | 04:24 AM
warp9's Avatar
My only defense is that I thought he was talking about a regular scroll T4. It was my bad for not reading the OPs post completely. I have never used a TS T4 so I wouldnt know, but as for a regular scroll I stand behind my testing. My apologies to the OP for rushing and not reading his post
Old Jun 10, 2010 | 01:24 AM
03whitegsr's Avatar
Originally Posted by AWD Motorsports
No, it was made because its what i believe..
Mike
Fair enough.
TedB and Drifto have made great efforts to show how much they BELIEVE in TS, just as you BELIEVE in SS.
Just as much as I'd like to see an even comparison that proved TS superior, I'd love to see somebody else prove other wise.
Fact of the matter is that if something truly works, fair testing done by either side would show the same results. Yet all we have really seen thus far from vendors is odd comparisons that seem to be grasping at straws in an effort to sell parts.
Old Jun 10, 2010 | 01:41 PM
riceball777's Avatar
i say stick with the twin scroll t4 housing opose to the tw t3
my twin scroll HTA gt3582r with the t4 1.06 housing can get 20psi in 3rd gear on the stock 2.0. definately spools way faster than any singile sfroll gt35r i have seen
Old Jun 10, 2010 | 01:53 PM
RSMike's Avatar
some people can't make 20psi in 3rd gear?
Old Jun 10, 2010 | 06:54 PM
open scroll gt35r's on stock 2.0 engine definately do not come close to making 20psi by 4k rpm in 3rd gear
