T3 vs T4 1.06 twinscroll housings, any power/response difference?
Definitely understandable... its just nice to see that swapping turbo platforms had such a nice effect. I will definitely lay my T3TS graph over the t4TS graph once we start that car. We are both using HTA3586s, I will be tuning both, and i will make sure we run the same boost level during our comparison runs and we will also do the comparsion on the street doing a few single gear pulls and then a 2nd thru 5th pull in order to really compare the 2 platforms. After seeing some of the results, i think ultimately a T4 platform would have been better overall if the spool is similar to better than the T3 is. I was kind of forced into this platform which is why i can remain unbiased with the comparison. I think down the road i may change to whatever is better. I just appreciate the twin scroll platform because it made my car fun to drive again. I didnt have that with the .82 on the 35R
Which is exactly why after trying TS following my previous setup (35R + open .63 T3), I'm not going back. Like you said, it made my car fun to drive again, and that's a top priority where my particular application is concerned.
Also guys don't forget that the graphs posted in here are T3 1.06 not T4 graphs.
The T4 twinscroll flange is the same one that has put cars into the eights..... not anything close to a T3 twinscroll or stock turbo flange.
Scorke
Scorke
I dont really have so much as an application as of yet. I daily drive mine, drag it occasionally and thinking of maybe hitting a road course or 2 in the near future when my Boss gets back from overseas. I think my personal car is right in the middle of the road to handle all 3. It wont be the greatest on those platforms, but will perform well in all.
"the difference in my car now is night and day the way my car picks up on/off throttle and the way pulls through the power band is unreal, the two graphs are off my car and the only thing that has changed is the turbo kits both were on a std inlet, I will hold my hands up and say that I am not up to speed on reading into the nitty gritty off graphs all that I can offer in feedback is that my car came alive with the fullrace fitted"
from this thread: http://www.lancerregister.com/showpo...0&postcount=57
your application is what I consider "all-around" and that is really where twinscroll shines. as you already experienced first hand, singlescroll works for drag, but wont hang on the street and road course.
Quirt Crawford will say the exact same thing. He did back-to-back on his Legacy GT, only changing the turbine housing (exhaust mani was divided of course, and perfectly fine to use with undivided turbine). He said the change in drivability was drastic, night and day.
Injectors were maxed... no doubt about that. I think I could have gotten more with it, but there was no reason to push the car for numbers when it was bordering on unsafe due to the injectors running out. That is a mustang dyno 470/420 that typically reads pretty close to Buschur's.
Here is the comparison between the 2 cars. To point out a few of the different variables involved...
- - - - Gt35R w/ .82 A/R / Not sure if it was with a built head or not, can't get a real answer / Different Tuner
____ HTA3586 T3TS w/ 1.06 A/R / Stock head / Tuned by Spec Ops / More room w/ more fuel
good discussion. 03white - i believe you may be overlooking the transient and torque benefits that twinscroll offers over singlescroll. Even IF the .63 spooled the same on a WOT dynopull as the 1.06, youre going to have huge differences in throttle response (esp at part throttle points) that the dyno wont show - as everyone who has felt the difference can attest to in this thread.
NOBODY has provided FACTUAL DATA relative to the setups we are interested in on this topic so I simply choose not to talk about it any more until somebody steps up and proves that point.
Just because the data is available to show acceleration improvements in commercial diesels or automotive diesel engines with tiny turbochargers limited to <3500 RPM doesn't mean it applies to high RPM gasoline engines.
I'm not "overlooking it."
I wasn't aware that they did...
Scorke
