T3 vs T4 1.06 twinscroll housings, any power/response difference?
from a few tests i saw running the 6466 its a promising turbo. but you also cant go wrong with the HTA86. its been a great turbo for me. i just feel that ****ty ATP part was holding me back and i wanted to give the PTE turbos a try. if it dont work out and i still have my HTA86 turbo then it will be getting a 1.15 and being put back on.
I've heard Garrett is coming out with new divided housings that will be made from Ni-Resist and use modern volute designs specifically for the GT turbine wheels.
Anybody have more info/"know if it's true" or even dates?
Hi from Australia .
Good peoples you are probably finding that the reason why its had to get a decent turbine housing for your GT35XXR turbo is because they are based on the smaller GT25 ball bearing center section .
Once you jump up a frame to the one used in GT37R/GT40R/T04R the problem seems to evaporate .
There is actually a couple of larger frame GT35 and GT35R versiona out there and I think they were OE on some Hino and Isuzu truck diesels . I think the Isuzu engine family was call Si Tek or something like that .
I think the turbine housing ARs were something like 1.05 and 1.17 ish and twin scroll T4 International style .
Note they were available in bush and BB cores , I have a damaged bush one here somewhere and I'll see if I can read its ID plate . May be able to cross reference turbine housing part numbers from there .
My one has an 82mm GT40 compressor I think in 82 trim and like most/all these bigger frame units it is a theaded bore wheel - no jamb nut .
Maybe an easy answer is to base some of these turbos on the GT37R core and fit an 82 or 86mm HTA wheel to that .
Damn shame there is no T4 TS GT30 turbine housings and I don't see Garrett ever doing them either .
A .
A .
Hi from Australia .
A .
A .
ATP has a recast 30R T4 housing but I havent seen that one, the 35R was less than desirable. What about an unmachined P trim? I think those were a 72.5mm turbine (37 stuff right?) but I know they had the larger sizes available.
aaron
Drifto saw 600whp using an HTA3076R, E85, and a 1.06 A/R divided T3 housing. Being that one cannot realistically expect more power using that turbo, it demonstrates that a T4 housing isn't necessary for GT30R setups.
I see that ATP lists a v-band 1.06 A/R divided T3 housing here:
1.06 TS T3
As for the ATP housings in general, I didn't notice any obvious internal fault with my 1.06 TS T4 unit. I checked the alignment, and everything appeared to be correct. I did clean some casting flash in the interior with a Dremel, but it was minor. I'm curious to know what others have found specifically that was disappointing.
1.06 TS T3
1.06 TS T3
1.06 TS T3
yes my T4 atp 1.06 housing was complete junk. the casting was terrible. when i pulled the housing off it was cracked in 4 spots on the inside divider. that is why i went with the PTE turbo and PTE T4 1.15 housing. which looks like it is made extremely well. i was supper happy with the casting
i have a HTA gt3582r with the divided atp 1.06 ar hotside with a full race t4 twinscroll manifold. This setup has been on my car for the past 4 years with over 80,000 miles with no problems. I wonder if my housing is all cracked up if i were to take the turbo/manifold off.
