T3 vs T4 1.06 twinscroll housings, any power/response difference?
From what I was told it is actually a Garrett casting, but from another application. I don't know what wheel you run, but cracking issues are likely caused by having to bore the housing for a wheel that is larger than the housing was originally designed for. In the several months I ran the housing cut for the GT30r wheel it had no issues, but I am now running the GT35r turbine wheel with no issues, but we shall see. Can you provide more detail to the problems you had so when I remove my turbo in the coming weeks I can check for these issues?
I got additional clarity. The t3 units are old AirResearch castings from some tractor application and you are correct, the new T4 TS units are ATP castings. I saw that you coated and wrapped the housing so that likely contributed to the failure. Not an excuse for the turbine housing, but something one should avoid if running this turbine housing. Was Precision able to cut the 1.15 for the GT35 turbine wheel?
thanks to Aaron at ER for all the help with the 35r 1.15 housing. he was the one who got me the info so he gets all the credit. it is not a PTE part. it is a Garrett housing machined for either the 35r or 37r turbine wheels. how do they do it? no clue. haha.
i want to add that the actual ''sand casting'' of the ATP part is so bad. all 3 housings i had all where different. i had to send one back before i used it for a replacement because the divider inside was not there for the last inch or so.
i spoke to someone ''idk if he wants me to say who'' about ATP vs Garrett housings. he said going from the ATP to a Garrett housing alone will net great gains for topend and less back pressure. if it was a Garrett 1.06 then going to a 1.15 you would see next to nothing. but ATP to Garrett he said there will be a nice gain. i wanted to gain the bigger turbine wheel while getting a better 1.15 housing. lets hope it works.
Good information and thanks. BTW, the units that cracked...where they T3 or T4 footprint? Also, did the new 1.15 unit provide the same placement/offset for the downpipe vs the ATP housing? Basically, was it a direct replacement and did you see any performance difference in spool/power?
So the 1.15 housing for the 35r (68mm) turbine exists???? I want now!
this just complicates things... 6266 in a 1.15, 6266 in a 1.15, efr8374 in a 1.05 or a hta86 in a 1.15?
once i get the new housing ill snap some pics VS the atp part and post them up.
Here is what I found...Garrett sells a standard 1.15a/r T4 TS cut for a P-trim turbine wheel. These units have the v-band flange welded to the back of the turbine housing so you would be able to determine if yours is the same based on this feature. Part number would also give it away. To make it work someone would have to obtain the virgin core to cut for a 35r turbine wheel. Looking forward to seeing some pics.
We have had 4x ATP housing fail over the last 18months, in both T3 GT30 twin scroll and T3 GT35 twin scroll.
They have informed me they are improving their material quality soon.
Must be costing them a bomb in warranty/RMA
Cheers, Mike
Cheers, Mike
warranty? haahhaha. maybe a warranty of a fancy convo piece in the garage.
i bet there 1.00 flows more then the ATP 1.06 though.
