T3 vs T4 1.06 twinscroll housings, any power/response difference?
Old Jul 19, 2010 | 03:06 PM
  #121
Geoff Raicer's Avatar
Originally Posted by scorke
the neat part about using a t4 twin scroll turbo setup is that it can accomodate turbos that can produce 600 to 1200 hp by just swapping out the turbo and nothing else. You cannot do that on a 2 liter motor with any other manifold setup on the market, none of them, be it t3, t3 twin scroll, or oem twin scroll
+1
Old Jul 19, 2010 | 04:30 PM
  #122
scorch's Avatar
would this be as easy as swapping the turbine housing of a t3 hta3586 to a t4 if your manifold is a t4 one?
Old Jul 19, 2010 | 05:07 PM
  #123
scorke's Avatar
Yes, pending the turbine wheel of the 3586 fits in a T4 flanged housing.
Scorke
Old Jul 19, 2010 | 05:11 PM
  #124
EvoDan2004's Avatar
Scorke
the turbine wheel in a 3686 is the same as a standard 35r. only the compressor side is modded and needed a new cover
Old Jul 19, 2010 | 05:49 PM
  #125
n2oiroc's Avatar
then you need this.
http://www.atpturbo.com/mm5/merchant...egory_Code=GTH
Old Jul 19, 2010 | 06:22 PM
  #126
EvoDan2004's Avatar
Originally Posted by n2oiroc
i do not need that. i was just stating its the same wheel
Old Jul 19, 2010 | 06:27 PM
  #127
n2oiroc's Avatar
you know what i meant. i was trying to throw the guy a bone.
  #128
EvoDan2004's Avatar
o ok. HA.
Old Jul 19, 2010 | 07:13 PM
  #129
scorch's Avatar
thanks for the help
looks to be an easy swap then.
Old Jul 20, 2010 | 07:46 AM
  #130
yes, just need to swap to twinscroll manifold and twinscroll turbine housing then add a 2nd wastegate - to convert a singlescroll HTA to a twinscroll
Old Jul 20, 2010 | 08:18 AM
  #131
03whitegsr's Avatar
Originally Posted by BLKCarbonEVO
I find it interesting that some people think that a T3 TS 1.06a/r will destroy the power potential of a turbo like the 3586. However, people like me and Mike at AWD have 700hp out of a stock cast 1.25" manifold with the extremely small stock TS housing on a Black...
So... If you go to a 1.25" tubular manifold (flows more than the stock cast), T3 TS 1.06a/r housing (much larger than stock housing), and upgraded to a 3586 (larger than a Black) then why could we not make 750+hp with great spool and topend? I would be willing to bet, a setup like this would only spool 200-300rpm slower than the Black and make a good 50hp more.
Mikey
Just my thoughts on this
The 67mm turbine stuffed into the EVO housing actually means a good deal of the nozzle is cut out of the housing. That stock housing may not appear all that large, but with a good portion of the nozzle cut out, I bet it flows considerably better then its size suggest. Cutting out the nozzle probably hurts efficiency though and having a better sized housing would likely show gains in mid-range. I don't think it would give you much on top end though as you are likely compressor limited at the 700HP level.
I don't think the stock runner is similar to a 1.25" pipe. It seems similar in cross section to a 1.5" pipe runner. I have not measured it deep in the runner to be sure, but I would beleive the stock manifold is much closer to 1.5" then 1.25" at its smallest cross section. Also, the stock evo manifold has a pulse converter shape cast into the runner to help reduce reversion... Look into this and get back if you think it is beneficial. I think it is especially considering the high EBP levels you are likely seeing at 600+ WHP. There isn't another aftermarket EVO manifold out ther that has this feature.
Old Sep 9, 2010 | 02:18 PM
  #132
ravnos04's Avatar
so it looks like i'll be going T4 instead of T3 TS now! tnx for the info!
Old Sep 9, 2010 | 05:04 PM
  #133
RunThat's Avatar
Same here! TS 4088 1.06 for my 2.1L Full-Race FTW
Old Sep 9, 2010 | 06:11 PM
  #134
ravnos04's Avatar
i like the results that ted.b has on his evo...i think i'm gonna go with the hta3586 1.06!!
Old Sep 9, 2010 | 06:32 PM
  #135
AWD Motorsports's Avatar
Much smarter than an OLD TECHNOLOGY cast wheel LAZY 40r IMO..
Mike
