Best 3" Cat
Old Nov 16, 2003 | 02:59 PM
MYEVOVIII's Avatar
Great pic's, I did not know that a replacement Cat would give youa check engine light. I thought only a cat delete would. This is why I was confused.
Old Nov 16, 2003 | 03:00 PM
SILVER SURFER's Avatar
Oh and here is my original dyno cat testing post using the Random 2.5".
https://www.evolutionm.net/forums/sh...+flow+cat+test
I tried to do some additional testing with the 3" Random but ran into some technical difficulties with the AWD dyno
Old Nov 16, 2003 | 03:06 PM
MalibuJack's Avatar
I think the Buschur CAT is made by Catco, incidentally is identical to the model I chose for my malibu (Used two 3" Cats).. (No, my malibu no longer has Catalytic converters, it just turned 25 and will be exempt next year when it gets inspected..
If you want to find a good high flowing performance cat that is low profile, look at the products made for the Domestic V8 cars such as the Camaro or Mustang.. All of them should flow enough for any of our 4 bangers.. plus the higher they flow, the generally longer they are because the exhaust needs to be exposed to more surface area in the Cat to reduce the emissions adequately.
If their wide and short, they can generate internal restrictions due to turbulence....
Old Nov 16, 2003 | 06:28 PM
FWIW, the guy I spoke with at Random told me they tested every type of cat they could find against the stock EVO cat, and this spiral metal substrate cat is the only one that flowed significantly better than the stock cat. This is all heresay of course, but my own limited testing seemed to agree.
IMO any cat that catalyzes as well as the stock cat will probably not flow any better either. Longer bricks=more restriction, IMO unless your willing to comprimise somewhat regarding emmisions, you mine as well stick with the stock cat. It really does flow extremely well for a stock unit, not suprising considering all of the other well engineered components put into this car.
Old Nov 16, 2003 | 06:31 PM
MalibuJack's Avatar
Your probably right.. Aside from the size of the inlet and outlet I doubt the cat flows much better.. At least with the larger inlet and outlet, your not restricting the flow by reducing the size of the pipes, which must be worth something.
Old Nov 17, 2003 | 10:46 AM
3deep's Avatar
I got one of the first 3" randoms and it flows extremly well compared to stock but I still get a cel.Where with the 2.5" version no cell.Im in the process of making my own cel fix.
Old Nov 24, 2003 | 11:05 AM
Dr Evo's Avatar
Re: Best 3" Cat
Originally posted by WOT
I was wondering which is the best performing cat?
I personally think that the North American Tabby is the quickest, but I've heard of some white Persians that can haul *** when confronted with a bucket of water.
LMAO
Old Nov 24, 2003 | 12:20 PM
wojo's Avatar
Re: Re: Best 3" Cat
LMAO
LOL. I had to take a double-read to get it though
Old Nov 24, 2003 | 12:40 PM
Aby@MIL.SPEC's Avatar
I amsuprised to see how long it took for somebody to have with with the wording of this post.
Seriously though, does anyone know what brand of catalytic converter is used in the Vishnu, RNR & AMS system?
Old Nov 24, 2003 | 01:42 PM
bullfrg's Avatar
WOT, I thought you were selling your EVO?
Old Nov 24, 2003 | 01:59 PM
USP45's Avatar
I have a catco and the CEL to go along with it. Kastle's Korner sent me a CEL eliminator as part of a three person beta tester group and the first try threw a different code. They are working on another one to send me to try out, I'll will post back how it goes, but at least they are trying to get a fix for other Evo owners who have the CEL.
Old Nov 24, 2003 | 02:10 PM
bullfrg, your. I am trying to sell this car. However, I still own it & am still going forward with my quest towards building it up if the funds become available.
Gaining evo 8 tuning knowledge isnt costing me anything, hopefully I can put it to good use & as well as anyone else reading these posts.
HELL, I still want to enjoy the car while I have it!
Old Nov 25, 2003 | 09:03 AM
bullfrg's Avatar
That is cool, I just thought maybe you had changed your mind about selling it. Do you have any more pics of your Evo? I am looking for one, I really want blue but silver is my second choice.
coachie
Jan 18, 2011 11:29 AM
SPARTAN-163
Lancer Engine Tech
Jun 7, 2010 09:45 AM
KY
Feb 18, 2007 11:22 PM
johny719
26
May 18, 2005 07:38 PM
Derek888
40
Nov 17, 2004 10:11 AM
