Motec vs. Gems - Best for Street/Track/Ease of Tuning
Old Jun 15, 2002 | 04:25 AM
KK's Avatar
KK
EvoM Administrator
Question Motec vs. Gems - Best for Street/Track/Ease of Tuning
Between the Motec M48 Pro and GEMS ecu, which is the easiest to tune for the Evo? From what I've seen. the Motec software is all DOS based and looks like a PITA to use, while the GEMS is really nice with windows that you can open and close to customize the look.
Also, I've heard that the Motec doesn't have any knock control... if so, that sucks Would using a J&S be a viable add on? I've also heard the Motec has a very fast processor which enables very accurate ignition spark.
Aside from those points what exactly are the main differences between the Motec and GEMS.
I've heard a lot of debate on these two, but I can't find enought points to know what exactly one does better than the other... down to the hardware and software capabilities, at least.
Thanks,
Mark
Old Jun 15, 2002 | 07:21 AM
TearItUpSports's Avatar
Based on what I have seen and heard, I would personally go with something like the TEC 3. I have heard it is pretty nice to use now.
It comes with nice coils, and good windows based software.
http://www.electromotive-inc.com/products/tec3.html
Old Jun 15, 2002 | 10:54 AM
KK's Avatar
KK
EvoM Administrator
Russ,
What does the TEC 3 cost on average? Any advantages/disadvantages.
I'm sure it's much more tedious to install, correct?
Mark
Old Jun 15, 2002 | 11:04 AM
It is a little more manual work than some others might be, but it shouldn't be too bad. The crank sensor would the the hardest, but electromotive is near to you. You might get them to make a bolt on one for the EVO.
Advantage is it has powerful ignition already built in.
I think it costs more than others. Maybe even in the $2K range. I can't see any disadvantages. One guy has used it on DSM's with great sucess. I think several use it on the WRX too.
Might look at the AEM one too, but don't think it is as powerful.
A lot of domestic guys going to Fuel injection use the TEC 3.
Old Jun 18, 2002 | 03:03 PM
Michaelk's Avatar
You shouldn't look at the M48 Pro anymore, but the M800 which should have all the features that you mentioned, I believe. But check for yourself at www.motec.com.au
Old Jun 26, 2002 | 12:26 PM
3171's Avatar
KK,
Are you going to map this yourself? Or is somebody going to do it for you?
Old Jun 26, 2002 | 01:22 PM
KK's Avatar
KK
EvoM Administrator
Someone would do it for me initially, but I would like to learn at the same time so I can be able to re-map in the future.
Mark
Old Jun 26, 2002 | 02:37 PM
3171's Avatar
i don't think its that easy to learn. also, if you mess up the map, you run the risk of blowing up your engine.
i am currently running a mine's ecu but am looking at getting an autronic unit (only because that is the only brand that i know of that is supported where i live).
good luck with whatever you decide to get
fatbastard
Jan 8, 2014 03:58 AM
DaveK
Nov 22, 2013 08:12 PM
Subi.convert
Dec 6, 2012 02:47 PM
59EVO
Oct 27, 2006 02:22 AM
alan678
16
Aug 14, 2006 07:51 AM
