Where do I go from HERE
Old Jun 8, 2010 | 08:33 PM
tdubbz's Avatar
Mods are in my sig. I went from stock to full bolt-ons + cams but unfortunately I got a bad tank of 93 when it was time for the tune and the car was knocking at 21 psi so I am stuck at 340whp. I could go back to CT and get a new tune for maybe another 10-20whp I'm guessing @ 24psi but I am getting bored and I am curious to hear what you guys think should be my next mods. My new goal is 400+whp, 11s in the 1/4. I want to stay on 93 NO meth...I think its cheating. What to do......
Old Jun 8, 2010 | 08:35 PM
borievoinitialD's Avatar
what dyno were ur numbers on??? fpred prob get u there
Old Jun 8, 2010 | 08:37 PM
06RedRalli's Avatar
FpRed and E85! 400whp Easy!
Old Jun 8, 2010 | 08:43 PM
tdubbz's Avatar
The #s are from a Dyno Dynamics with 1.2 correction. More like DJ #s
Went the strip for the first time. Didn't launch hard and I was trapping 107-108mph if that helps....
I was thinking FP Red and some 880cc injectors and call it a day. HTA Green interest me but I'm sure I will want room to grow with the red.
Old Jun 9, 2010 | 06:24 AM
tdubbz's Avatar
How much boost can I safely run on my setup with a RED?
Old Jun 9, 2010 | 06:30 AM
JakeTheVIII's Avatar
Probably between 26-30psi. Yea I would go with the red. Your main limiting factor is the stock 8 turbo.
Old Jun 9, 2010 | 08:36 PM
tdubbz's Avatar
thanks.... looks like its time to for a Red!
Old Jun 9, 2010 | 08:40 PM
SpeedySam's Avatar
Red with E85..
Old Jun 10, 2010 | 01:27 PM
tdubbz's Avatar
No E85 close to me. Is the red going to underperform that bad on 93, under 30psi?
Old Jun 10, 2010 | 01:39 PM
Draven83's Avatar
yes it will underperform on 93, mine didnt wake up till i put 100 in there and really awakened when the e85 went in it.. but with a good tune you should be able to get close to 400, also get a FMIC thats holding you back some also.
Old Jun 10, 2010 | 02:02 PM
tdubbz's Avatar
hmmm well I have a big Perrin FMIC so I'm set there but maybe a HTA Green would be more suited for 93?
I'm getting some 880cc injectors so I will have some room to grow....
Old Jun 10, 2010 | 02:44 PM
RockmanX's Avatar
i would say stick with the red and get no less then 1000cc injectors
Old Jun 10, 2010 | 03:03 PM
DJ Brett B's Avatar
What are your goals for the car? Do you want a faster spooling turbo since you are sticking to 93 octane (no e85/meth) or do you want a peak-power turbo and have the room to later switch fueling options? FP green HTA or BBK turbo for fast spool, fp red or black for more lag/peak power- once you decide which turbo choose the appropriate size injectors to accommodate it. 880cc would be the smallest I would go...
Bigboost1320
12
Jun 22, 2015 03:44 AM
N33d4sp33d
Sep 20, 2013 02:46 PM
JohnnyEvo21
May 27, 2013 08:37 AM
cvnick
Oct 9, 2011 05:03 PM
mitsuevo803
392
Feb 22, 2010 07:25 PM
