6 speed disassembly guide??
Old Jun 11, 2010, 12:26 AM
elhalisf's Avatar
I am trying to take apart a 6 speed transmission, but I am not having any luck separating the case apart. One of the shift rails still seems to be locked onto the case by one of the interlock *****/pins. I have been trying for days to get the ball to come out, with no luck.
I can hear the ball going back and forth.
Does anyone know how to take it apart or have a tech guide on how to do it?
Old Jun 11, 2010, 04:48 AM
thedru13's Avatar
Good Luck elhalisf.. I tried to get mine out Pulled and pulled nothing. I was afraid to really yank didn't want to break it. I can take pics of a donor trans i have with the shifter pulled out if it will help but I was not able to get mine to release. I also was not able to ever find any tech on the 6sp..
Old Jun 11, 2010, 05:09 AM
MR. EVO MR's Avatar
will a hard rubber mallet help?
GL
Old Jun 23, 2010, 09:05 AM
elhalisf's Avatar
Still needing help with this!
Old Jun 23, 2010, 10:41 AM
94AWDcoupe's Avatar
This tranny is much the same as 5 speed. The only trick is there are two rubber freeze plugs on end of tranny. They need to be removed. One is hiding a allen head bolt, the other hides a snap ring that needs to be held open to get cases apart. The shift rails are not holding the top case from sliding off.
Aside from that you really need the diagrams to dissasemble the shift rails to get the gearsets out. Its not simple like the 5 speeds. lots a small parts..
Live4Redline
27
Apr 14, 2018 04:13 PM
LordCthulu
Jul 13, 2017 05:10 PM
Evo_Goodness
Sep 29, 2016 10:31 PM
Zach Richardson
Sep 9, 2016 07:24 AM
boostd97gst
Sep 22, 2009 04:48 AM
Quick Reply: 6 speed disassembly guide??
