Boost controller - evo 9
Old Jun 11, 2010 | 04:07 PM
joshdunn87's Avatar
I have a '06 evo 9 with intake, exhaust, and ecu tuning by forced performance. I was looking into putting in a boost controller to get a little more out of the stock engine/turbo. Yet I dot want to put too much stress on the units. I have about 11k miles on the car and about a third of them are track miles. If I were to install one I would use the manual hallman pro kit or the hks ez boost controller.
Thanks for the help.
Old Jun 11, 2010 | 04:18 PM
erald01's Avatar
you cant just turn the boost up without a tune, so DONT DO IT or your engine will be in pieces. Put a boost controller (hallman are really good ones) then get the car tuned. I always say install the boost controller the same day you get your car tuned, so you can turn the boost as you adjust the tune
Old Jun 16, 2010 | 06:33 PM
negativegeforce's Avatar
The stock Evo maps cant handle boost increase very well.
I had light knock counts just after installing a turbo back exhaust and had to adjust the timing map. Definitely get it tuned before turning the boost up.
Old Jun 16, 2010 | 06:46 PM
milford's Avatar
he never said he was going to put it on without a tune....
Old Jun 16, 2010 | 06:48 PM
SlowSportSedan's Avatar
Check out 4WSTuning.com, 4ws tuning on evom.. He'll help you pick the best parts for your money and tune the car. I paid $150 for my tune from him and it makes a ton of power.
Old Jun 17, 2010 | 11:07 AM
joshdunn87's Avatar
The car its tuned to 14 psi which I assume is stock, if I were to have it tuned and push it to 23 psi would the stock engine/turbo be able to hold all of the new power
Old Jun 17, 2010 | 01:29 PM
SavEVOIX's Avatar
I believe stock is 19psi and tapers down. I am able to run around 22psi on 91oct.
Old Jun 17, 2010 | 03:56 PM
andrewzaragoza's Avatar
get it tuned. i suggest using ecu controlled boost via 3-port. i see you are in dallas. https://www.evolutionm.net/forums/no...club-ntec-303/ for your tuning needs you could go to evolutiondynamics.
Old Jun 17, 2010 | 04:06 PM
JonahEVO's Avatar
Lmao, tuned at 14 Psi? Never heard of that before. QUOTE=joshdunn87;8413465]The car its tuned to 14 psi which I assume is stock, if I were to have it tuned and push it to 23 psi would the stock engine/turbo be able to hold all of the new power[/QUOTE]
Old Jun 17, 2010 | 04:44 PM
304MR's Avatar
I put the hallman pro on mine and had no prob with setting mine to 20 psi. You can go to 22 untuned but with a few mods my knock went crazy. At 20 its ok but best the best thing is that the taper effect stops.
Old Jun 17, 2010 | 04:48 PM
Gleason at STM's Avatar
The Hallman Pro is a good Manual Boost Controller choice. It is relatively cheap, looks awesome, consistent, and reliable! We run them on everything we build, and even have one on our STM "RICER" Evo !
Check out more pictures and information here!
Any other questions feel free to send me a PM anytime!
-Brian Gleason
www.stmtuned.com
Old Jun 21, 2010 | 11:44 PM
P_Tune_C's Avatar
hallman pro has always been best choice for boost controller, price is just right, and works even better than some Electronic boost controllers out there!
Old Jun 23, 2010 | 10:15 PM
casper980's Avatar
Yes the stock engine will be able to hold the power, even for road racing. You must have it tuned, Hallman pro is a good choice. Mix a couple gals of 110 in when your at the track if you want to be safe. If your only making 14lbs, thats stock wastegate pressure, somethings wrong. Do a boost leak test.
Old Jun 26, 2010 | 10:03 AM
joshdunn87's Avatar
Got it tuned by evo dynamics to 22-23 psi @ 310whp. Decided not to use a boost controller. Next mods will be walbro fuel pump. Then down and test pipe. Any suggestions on pipes?
Old Aug 15, 2010 | 06:00 AM
juanpdu's Avatar
greddy ti-c the only one that is 80mm not 76mm as hks and ams. greddy all the way
Robross
Australian Forum
Jun 4, 2016 11:42 AM
Kevoix
Apr 10, 2016 10:12 AM
jshkaz
Sep 26, 2013 06:09 PM
whotippedmycow
Jun 19, 2013 06:03 PM
