Car Bog during launch
Old Jun 12, 2010 | 06:51 AM
EvolNinja's Avatar
My buddy decide to call me out to the street drag at a race track. I was racing with another fellow Evo 8. I did poor last night. 2 times I launch, no launch was just normal rev and go, car bog then pick up boost after the other car is 2 car ahead of me. Second I launch and same thing. Third, I just let him win because there is no way I want to race again.
I think I found my own answer. Prior to the race, I found that my INTAKE pipe where the coupler goes to the turbo inlet was loose and I was going to tighten that the same day except I had no time so I just went without tighten that sucker. I believe that might have thrown my MAF to read in correctly, therefore causing the bog? Hope it's not any things.
Anyone?
Old Jun 12, 2010 | 11:35 AM
Toxin's Avatar
Slip the clutch next time.
Old Jun 12, 2010 | 12:27 PM
heel2toe's Avatar
When you tried to launch the car were you on the 2-step? What RPM do you have it set at? I have never launched my car and dont plan to as I cant afford a new clutch or whatever else I may break but it sounds like your launching at too low of an RPM or are not slipping your clutch properly thus causing the car to bog.
Old Jun 12, 2010 | 09:57 PM
EvolNinja's Avatar
Well, I tighten the clamp today. Took her for a spin and she pulls hard as before. Just need to finish my tune after a couple upgrades I put in. Also want to go e85 too so I'm going to do it at once when I get my new injectors. You guys think PTE 1000cc will do fine for a 430hp range? or should I go with PTE1200?
Old Jun 12, 2010 | 11:04 PM
MonsterEvol23's Avatar
You should be fine running the 1000cc injectors for 430 whp, and a little room for more.
Old Jun 13, 2010 | 06:18 AM
hitman28's Avatar
you didnt have time to tighten a coupler,but you had time to set up a race?
akira2_03
21
Dec 5, 2016 01:46 PM
Ev0_J0e
Mar 31, 2009 05:07 PM
Rallilanc
63
Mar 14, 2008 04:46 AM
Doug88
Oct 29, 2006 12:35 PM
