Does anyone have a 2.3 RR ?
Old Jun 12, 2010 | 07:03 AM
Shy's Avatar
Shy
Smile Does anyone have a 2.3 RR ?
Hi there!
Does anyone have a 2.3 RR i can talk to for feedback please?
Appreciate any help i can get!
Thanks
Old Jun 12, 2010 | 07:09 AM
wreckless969's Avatar
Originally Posted by Shy
Hi there!
Thanks
I don't have pone but I did almost buy one and after looking around and doing a lot of research its not really worth it.
For what its worth I ended up going with a BR 2.3 with a custom compression ratio and it cost less then half of what the AMS block cost and it'll still spin to 8500 if you really want.
Old Jun 12, 2010 | 07:23 AM
bluebanana23's Avatar
I believe Sharkbyte##### does. He mated the 950R kit with it.
Old Jun 12, 2010 | 01:13 PM
20gmr's Avatar
I know of one that failed.... I personally never owned one. The 4g is such a common engine I would never pay what they are asking for it. I understand they use quality stuff but most of it is the AMS name tag you are paying for.
Old Jun 12, 2010 | 01:28 PM
RockmanX's Avatar
you can get a LR2.4 to be honest with you and get results you are aiming for. I know of one person on here that has one in fact i take that back i know two people. One guy i never talked to another guy owns the bby cbrd voltex evo forgot his name but you can ask him but john bradley ER should chime in and im sure its easier and cheaper to get a LR2.4 anyday of the week.
here is his car
Old Jun 12, 2010 | 01:41 PM
JohnBradley's Avatar
I think the 2.3RR and the LR2.4 are almost the same in what they will accomplish. They are not the same motor to be sure, the 2.4 is 80cc larger but seems to be able to rev the same and continue to make peak power. Here is my dynograph-
I will go find the AMS 2.3RR dyno graph and post it underneath.
EDIT-
Full link
https://www.evolutionm.net/forums/au...nd-inside.html
Old Jun 12, 2010 | 03:20 PM
bbyevo8u's Avatar
^^ what turbo was that with, and how much boost?
Old Jun 12, 2010 | 03:27 PM
Teal2nnr's Avatar
Not sure were the money goes in that engine....I guess your getting piece of mind from having it built by one of the best companies out there. But i don't think i would be looking at that motor any time soon.
If i was going all out i'd be looking at a Magnus motor.....or BR with some extras
Old Jun 12, 2010 | 04:04 PM
Broham's Avatar
THe machine work and that crank is what is going to run you a lot for that money. You have to remember when that much machining is going on there is a premium to pay. Is it worth 8k? well that is rather a lot.
most places the 4g motor is 5-600 short block or 300 with no crank. Add in the machine work. around 2500 at a good shop with oil squirters cleaning and assembly included. the crank for 1g = 3800. Piston and rod probably 16-1700. you're already at 5500 without the mainstuds, headgasket,oilpump,waterpump, and balance shaft. I'm guessing at 8k they are making no more than 500 - 800 in profit per engne. Which is still a lot. but who knows i may be completely off. either way. Now the crate motor is where it doesn't make sense. from 8k it goes to 15k. 15k!
us bargain hunters will get an old block, machine it, get rods/pistons bearings etc and use the 9 head and get a gasket. bam! probably 5k done not 8. and not no 15k. with 15k you can get a transmission clutch and turbo kit. full customization for 15k
pardon the finance rant.
Old Jun 12, 2010 | 05:00 PM
RockmanX's Avatar
lol us really really really good hunters and deal makers get
built head(cleaned redecked ported oversized valves custom spring and retainers)
built std2.4(cleaned wesico,ibeam acl brearings arp main studs 100mm crank assembled)
ams custom 2.4 headgasket
Arp undercut headstuds
tension,idle pully
fluidampr
SBR 2.4 timing belt
SBR waterpump adaptor plate
waterpump
Oil pump with gears(frontcase)
Balance shaft eliminator kit
for less then 4700 all parts are brand new NO CORE but that takes time searching and looking for deals my friend
Old Jun 12, 2010 | 08:04 PM
Links are your friend
30psi on Q16 for the 645/493 according the AMS thread.
Mine was 92 octane and 25.7psi with a 3586.
aaron
Old Jun 12, 2010 | 08:25 PM
RockmanX's Avatar
yo aaron if your online pm me please i have a friend with at 2.4 issue
Old Jun 13, 2010 | 09:46 AM
BLKCarbonEVO's Avatar
Shark has a std 2.3, not the 2.3RR.
OP, I agree with everyone else. The 2.3RR is not worth the money. You can get a LR2.4 for less and it will perform just aswell. I love my LR2.4 more than anything.
JohnBradley (Aaron) from ER can hook you up with a LR2.4. He has built quite a few and the list is still growing! Signup!!!
Mikey
Old Jun 13, 2010 | 09:58 AM
EvolvedGTI's Avatar
here is his car
Rock, the guy you are referring too is BlewByYouEvoVIII (Ryan). He is here in ATL!
eddy5201314
13
May 18, 2020 02:55 PM
foxbear2277
33
Dec 7, 2014 03:40 AM
Shy
Jun 12, 2010 07:00 AM
Noob4life
Jan 19, 2009 05:35 PM
jmsrx
24
Dec 18, 2007 11:15 AM
