Max tq on Crower Rods?
Either is going to handle whatever you can throw at them, but the Crowers weight 11-12% less.
Are you're referring to the inexpensive H-beam rod, which is made in China and rebranded? If so, that isn't something that shouldn't realistically be considered in this application.
The Manley rods are DEFINITELY much nicer than the Crower rods. I'm running Manley's now. Their tolerances were held beautifully and they are a much tougher rod than the Crowers.
Kevin
Kevin
we've run both... Manley turbo tuff seem to be better for us at least.
and if you're going crazy... just upgrade the rod bolts to +625 aged ones. One thing to watch for that everyone seems to neglect is the piston wrist pin. Most off the shelf pistons use pins that are rated up to about 700hp. They are very thin wall'd even compared to stock beefy wrist pins. Minus the alloy. U can easily upgrade these on most brands as well.
they look like this
guyver858
Sep 9, 2015 10:53 PM
Minnesota MR
Jan 4, 2011 04:14 PM
