Another SPEC Clutch Issue
Old Jun 18, 2010 | 12:11 PM
cssaddictm4's Avatar
I spoke with both SPEC and QuarterMaster regarding this issue. Both of them have no idea of what it could be...This is the Spec Super Twin SM80SST.
I have a squeak from the clutch (bell housing side) which I believe is the hydro throw out bearing when engaging and disengaging the clutch pedal. Keep in mind this is only happening while the engine is running. Sometimes this causes the clutch to be *stuck* to the floor/engaged and will either pop back up on its own or with some persuasion. Interesting part is that the squeak will go away after about 20minutes or so of driving. I also noticed that the engagement point is changing because I noticed the car would start to roll forward when going into first, and I had to back out the clutch rod some more.
AMS SS line installed, new master installed, and the system is bled.
Any insight would be appreciated.
Video for reference:
http://www.youtube.com/watch?v=92QvZyrr3so
Old Jun 19, 2010 | 05:38 PM
Any ideas welcome. I priced out a throw out bearing from Spec @ 311$. Maybe a bad master cylinder? I know its like shooting in the dark but I don't want to fork out the money and not fix it. I would rather get a whole new clutch kit instead while its apart.
Old Jun 25, 2010 | 10:21 AM
daisaw1219's Avatar
ive had similar issues, now after only a year my hydro tob is leaking
Old Jun 25, 2010 | 10:40 AM
Do you have the same clutch kit, or are you utilizing the same TOB? I just ordered another master cylinder just to be on the safe side. I figured it was initially a potential cheaper solution than pulling the transmission.
Old Jun 25, 2010 | 10:44 AM
94AWDcoupe's Avatar
the video sounds like all the noise is coming from inside car. if thats the case it would have to be the master. which is also consistent with the pedal sticking to the floor.
Old Jun 25, 2010 | 12:14 PM
daisaw1219's Avatar
i have the same clutch kit, in PT trim.
Old Jun 25, 2010 | 12:24 PM
heavens turbo's Avatar
man that sucks. i would cry. yeah, maybe the internal seals of the master are bad. or the tb has an issue. sorry, not much help, but i would replace master and check install of everything again. good luck.
Old Jun 26, 2010 | 05:37 AM
Well the worst part is that I can't bring her back down to NJ to get her tuned until I know she's 100%. Last time it was the most expensive waste of time that I ever had. I cried at paying 600$ to find out that I have to come again and shell out another 600-800$.
I have not heard back from Spec so it seems like they are running away with their hands in the air. The new master I ordered will be here Wednesday at the latest. I am crossing my fingers that this will solve the issue. If not it is likely that she will have to be down for another year (I am close to my budget cap).
nor11384
Nov 21, 2022 07:23 AM
240Z TwinTurbo
Aug 28, 2017 07:34 AM
Kris86
Oct 5, 2016 10:31 AM
The_Police
Apr 6, 2016 07:05 PM
Ralli04
May 7, 2007 05:29 PM
