HTA Green Boost Spiking :( Anyone else got this problem?
#35
Let me start by saying that I had the exact same setup as you. HTA Green 64mm, APS Twin vent, and 18psi WGA. I was getting TERRIBLE surging during spool up and boost spiking up high. It was a combination of the compressor cover and the BOV. My BOV would flutter and couldn't hold up to the 35 psi I was running with the HTA. Your only option is to either turn the boost down significantly to cut down on the compressor cover surge or at least change up the compressor cover. Once I switched to the 84mm Flow advancement port and the Tial QR Recirculating BOV I have had 0 issues. It is a night and day difference. The HTA is prone to these problems since it is using a standard 64mm stock flowing inlet and flowing significantly more air than the stock turbo. This causes spool up to be very rough and surging issues. I am telling you, I tried every solution, 25psi WGA, ECU boost, everything, nothing solved the problem until I purchased the 84mm port and a new BOV. Now it is flawless. Perfect DD combination and the spool up insane and smooth as butter.
I saw you said you don't want to upgrade, but I exhausted all options before I did and nothing worked... Sorry but your going to have to sink some money into her...
Well I finally did the compressor cover and 18psi actuator. I didn't think it was the aps bov, so I kept that. I went ahead with the fp intake and cut the hose to fit the perrin intake heatshield/maf. Took it out today and did a 3rd gear pull. Boost hit 22psi and literally stayed there like it was stuck, all the way to redline. I couldn't believe how steady it was. It was like someone reached in and held the needle so it wouldnt move. I can't believe the difference. And the ported compressor cover sounds much more wicked than the stock ported one. Thanks for the helpful info buchnerj. Gonna go ahead and set up the tune. Will keep ya posted.
#36
Finally got the car tuned, and it feels like a beast! One thing worth noting though, is that boost sat perfectly at 22psi initially, but as I approached redline, it would creep up to 23-24psi. Not sure what caused it, but we worked it out. Anyone know what may be causing this? I thought usually you would see taper.
#37
now its "creeping". Some ppl like creep. You can use it to your advantage, as long as u run reasonable boost levels before it creeps, and tune your fuel/timing, to compensate.
to eliminate the creep, you need to port the wastegate hole in the o2 housing.
https://www.evolutionm.net/forums/ev...bs-thread.html
#38
#39
embrace the creep. it means your wastegate is not flowing that well. this forces the pressure over turbine where it can do work. a little bit of creep is a good thing. lower rpms is where engine is most likely to detonate. higher rpms the piston speeds are so high there is no time for it to occur. those who are aware of this try to make the boost curve creep.
#40
I'll will be testing this in a few weeks with my new HTA Green and psi based boost control ....
#41
Exactly...I always wonder why folks don't have the "boost spike" set lower (e.g. 27 psi @ 3500 - 4000 range and gradually increase the boost e.g. 32 psi at 7800 rpm - the shock to the drivetrain would be less (good thing), you'd have a flatter torque curve (easier / better for racing), and great hp up top...
#44
The surging problems were a real PITA, and really made the car less fun to drive, because you had constant bucking and hesitation. With the free flowing cover and smooth boost, it feels like a totally different car.
Have fun with it, and be safe
drb
Sep 22, 2015 08:47 AM
David Buschur
Sep 6, 2015 09:27 PM
