Did a compression test.. wtf
Old Jul 18, 2010 | 04:25 PM
srtboostin22's Avatar
So recently my car just started blowing blue smoke out of the exhaust. It only happens when i start the car, and when i take off from red lights and stop signs.. BUT the car still runs great.. just blue smoke.. anyway, decided to do a compression test..
Cyl #1: 140
Cyl #2: 125
Cyl #3: 50
Cyl #4: 70
For some reason it makes no sense to me, because the car still runs great, could it be my valve seals?.. any thoughts? thanks guys..
Old Jul 18, 2010 | 04:36 PM
Evoryder's Avatar
how many times did you do the test? Those results definitely don't look right.
Old Jul 18, 2010 | 04:38 PM
Werd's Avatar
head gasket.
Sharkbite2000's Avatar
Do it again make sure your not leaking you know tight seal.
Old Jul 18, 2010 | 04:42 PM
apagan01's Avatar
Cyl #1: 140
Cyl #2: 125
Cyl #3: 50
Cyl #4: 70
Blue smoke is oil no doubt of that, so low numbers point out to blow by,,, however i hope thats not the case for you.
-Compression test it again making sure the engine is fully warm.
- if not satisfied with results, put some oil into the cylinders and test again, the oil will help seal the rings.
but looks like shot rings,, specially when you are saying that blue smoke come out when starting,,, i also bet you that at WOT you are blowing blue / white smoke out the back.
GL
Old Jul 20, 2010 | 07:13 PM
MRfabolous's Avatar
Ygapm boostin
ISPEVO8
Feb 27, 2017 07:01 PM
SeahawksOilers
12
Apr 26, 2014 09:11 AM
Throttle
20
Jan 21, 2012 07:41 AM
mmmmbst
34
Apr 14, 2009 03:06 AM
cantcatchme96
Lancer Engine Tech
Aug 22, 2008 12:32 PM
