ex mani install leads to lose of boost?
Old Jul 21, 2010 | 07:39 PM
section8evo's Avatar
so i put an invidia exhaust mani on the other day an now im losing boost, all the bolt are torqued down to proper specs, i also checked all my intercooler piping an intake piping , everything is good, so the only thing i can think of is its gotta be something to do with the exhaust mani, any input?
Thanks
Old Jul 21, 2010 | 07:54 PM
GG_9_SE's Avatar
Um the mani could be cracked but thats an exhaust leak. do a boost leak test son! could be anywhere do you have upgraded throttle body shaft seal? maybe you popped a vacume line off somwheres? maybe missed tightening a clamp down by the intercooler. a real boost leak test will tell you.
Old Jul 21, 2010 | 07:57 PM
yeah im gonna have to look into the boost leak teast, an its deffently not an exhaust mani leak, i checked that already, but no upgraded TB shaft seal, an all the vac lines are good, checked em a few times, ill do the boost leak test in the AM
Old Jul 21, 2010 | 08:04 PM
aaevol9's Avatar
more than likely if you had a cracked exhaust mani that was causing you to loose boost you would deffinately hear it, sort of tractor sounding...but do the boost leak test first and then go from there.
Old Jul 21, 2010 | 08:07 PM
hahaha yeah no sort of tractor sounds as im going down the road, but im deffently gonna check everything again to make sure an then do the boost leak test
1BADSS/SC
Jul 2, 2011 03:26 PM
Racecarzz08
Lancer Engine Tech
11
Feb 1, 2009 05:07 PM
kstpeter33
15
May 29, 2007 01:50 PM
EVONation
Feb 18, 2005 11:06 AM
evo8power
12
Nov 5, 2003 04:56 PM
