Safety latching turbo bolts
Old Aug 2, 2010 | 08:52 AM
RunThat's Avatar
Originally Posted by hotrod2448
ARP usually has a decent selection of pre-drilled 12 point bolts. The safety wire and pliers can be had at McMaster Carr. MMC also has a good selection of pre-drilled bolts.
On the MMC website:
Safety wire pliers: 5296A25
.025 safety wire: 8860K62
Here is a good write up on how to properly safety wire:
http://www.whizwheels.com/Tips/safetywiring.html
Which ARP part #'s for the manifold to turbo and turbo to O2 housing bolts, studs, etc?
Old Aug 2, 2010 | 07:05 PM
RunThat's Avatar
Question
Anyone know the correct size Nord Lock washers I need for the stock size exhaust manifold to turbo bolts/studs and for the stock size turbo to O2 housing bolts/studs? I'd like to order them right away. Thanks!
Old Aug 2, 2010 | 07:24 PM
240Z TwinTurbo's Avatar
Use Stover Lock Nuts and you will never have a problem. Keep in mind they are intended to be installed and hold in place. Therefore, if you have to remove you need to chase the threads with a thread chaser and not a thread cutter. You will also need to use new Stover Lock Nuts.
http://coburnmyers.thomasnet.com/vie...over-lock-nuts
Old Aug 2, 2010 | 07:30 PM
RunThat's Avatar
What size?
Old Aug 2, 2010 | 08:50 PM
R/TErnie's Avatar
Interesting solutions.
If you run extended periods on the track you will need to safety wire the bolts... I haven't found anything short of safety wire that keeps them from backing out.
Old Aug 2, 2010 | 09:14 PM
igo4bmx's Avatar
i use these and they are AWESOME
http://www.stage8.com
Old Aug 2, 2010 | 11:13 PM
RSMike's Avatar
yup, thats why Lockwire is used on Aircraft. I've used it on turbo bolts before, worked a treat
Old Aug 3, 2010 | 07:14 AM
RunThat's Avatar
Can someone PLEASE post the bolt and stud size and thread pitch for the manifold to turbo as well as the turbo to O2 housing.
Old Aug 3, 2010 | 09:14 AM
igo4bmx's Avatar
M10 x 1.25 most likely 30 mm for o2 housing and 90mm for turbo to manifold?
Old Aug 3, 2010 | 09:29 AM
igo4bmx's Avatar
here's a video on nord locks for those interested.
http://www.youtube.com/watch?v=mgwmuZuJ02I
Old Aug 3, 2010 | 10:06 AM
igo4bmx's Avatar
Im trying the nord lock washers
this is what im buying from mcmaster
Qty 2 of 91812A231 Nord lock M10 washers (10 pairs)
Qty 1 of 91180A634 M10 x 1.25 30mm bolts (pack of 5 for o2 housing)
Qty 2 of 91028A667 M10 x 1.25 JIS Hex nut (pack of 5)
EDIT lookin for exact manifold to turbo bolt length...
QwikEVO
Aug 23, 2015 11:10 AM
Lightsaber
Feb 19, 2014 06:46 AM
WavMixer
33
Feb 8, 2012 10:29 PM
webguy330i
Sep 15, 2005 04:38 PM
vtluu
Jul 11, 2005 09:15 AM
