trouble going in gear
Old Jul 31, 2010 | 06:30 AM
ATTAHO's Avatar
I have had my evo for several months without issue, but this morning I tried to put it into reverse and it made a slight grinding sound. Then when I tried to put it in first it was really stiff. I drove it for a bit and noticed it is only a problem when I'm NOT moving. If the car is rolling even a little, its smooth as the day I bought it.
I have not changed any aspect of the car, Never tracked it. Its my DD so I pretty much baby it with small spots of spirited drivning in between. So I'm kinda at a loss of thoughts.
I have checked: Clutch fluid level, trans cables,
Old Jul 31, 2010 | 10:05 AM
Berts24's Avatar
could be the clutch going, I had the same issue when my clutch went out especially reverse
Old Aug 1, 2010 | 10:38 AM
chu's Avatar
chu
I'm having the same problem. The trans is going down tomorrow. My clutch isn't slipping at all. I think its a bent clutch fork! I will update as my problems get resolved.
Old Aug 2, 2010 | 06:01 AM
ATTAHO's Avatar
sweet, thanks for the input. The clutch doesn't slip at all. And it still engages at about the same level which is a ways above the floor. Thats why I don't think its so much the clutch.
Old Aug 2, 2010 | 05:49 PM
Evo8luva's Avatar
What kind of clutch is it?
Old Aug 2, 2010 | 05:53 PM
jy951's Avatar
Try adjusting your clutch pedal. There is an adjustment on the clutch master. Your clutch may be dragging.
Old Aug 2, 2010 | 10:09 PM
ATTAHO's Avatar
its a stock clutch. I will check the adjustment, but the clutch disengages so high i doubt thats it
Old Aug 2, 2010 | 10:12 PM
tim85851's Avatar
im having the EXACT same issues with my Cusco Twin Disk...bump for some updates.
no slipping at all. just grinds in reverse...but if the car is rolling back a little bit reverse is smooth...and putting it into first is really hard...
Old Aug 3, 2010 | 09:40 PM
ATTAHO's Avatar
bump?
Old Aug 3, 2010 | 09:47 PM
4g63Moon's Avatar
How do you adjust the clutch pedal?
Old Aug 4, 2010 | 12:02 PM
diablo1's Avatar
I have the same problem, in for some updates!!!
jwick76
Lancer Engine Management / Tuning Forums
Dec 12, 2012 09:54 AM
Evo1001
27
Jan 16, 2012 11:52 AM
Tekknian
Sep 25, 2011 10:20 PM
Ralliartize It
Jun 23, 2010 09:59 AM
EvosLilBro
Aug 30, 2005 01:28 PM
