clunking/rubbing noise from under the car
Old Aug 20, 2010 | 09:11 PM
racr00089's Avatar
My car started to make a rubbing noise a couple weeks ago and now it has turned into a clunking that i can almost feel in my seat. I thought that maybe my drive shaft was out of balance becuase my exhuast has been hitting it cause its way to loose. I got a good deal on a used drive shaft and replaced it. Same problem. Does anybody know what this could be? Also the dealorship replaced my clutch about 2 months ago if that might have something to do with it.
Old Aug 20, 2010 | 09:19 PM
stackhouse's Avatar
r u sure the rubbing noise wasnt the exhaust hitting the driveshaft a little, then gettting looser, and hitting it harder, thus, the clunking? So you just replaced your driveshaft without fixing the loose exhaust? If so, i wouldnt be suprised that its still "clunking". Need to get that exhaust tightened up.
Old Aug 20, 2010 | 09:23 PM
racr00089's Avatar
I forgot to say that i put the stock exhaust back on. theres now way that its hitting the driveshaft now. Has to be something else.
Old Aug 21, 2010 | 07:23 AM
racr00089's Avatar
still nobody? I need this fixed asap guys the evo's my dd.
Old Aug 21, 2010 | 09:50 AM
stackhouse's Avatar
under what conditions do you hear the noise? does it increase with engine speed? vehicle speed? Does it do it at idle? In a certain gear? At a certain speed? When you hit bumps? With little to no details, theres so many possibilities. With that being said, my next guess would be suspension.
Old Aug 21, 2010 | 10:04 AM
racr00089's Avatar
It does it all the time above probally 10mph and it changes slows down and speeds up with the engine speed. It does it with the clutch in or out and also in any gear. bumps dont affect it.
Old Aug 21, 2010 | 10:10 AM
usacchamp's Avatar
Check the exhaust mounts
Old Aug 21, 2010 | 10:12 AM
racr00089's Avatar
Do you mean check the rubber hangars and make sure their all connected?
Old Aug 21, 2010 | 07:21 PM
racr00089's Avatar
i feel like an idiot to admit this, but it was loose lug nuts. That should have been the first thing that i checked. I guess paying the dealor 1300 to install a new clutch, still isint enough for them to tighten your lug nuts all the way.
Old Aug 21, 2010 | 08:34 PM
stackhouse's Avatar
Nope, torquing the lug nuts gonna cost u extra.
So, the clunking was your front wheels sliding around on the studs? Ouch...
Old Aug 21, 2010 | 08:54 PM
racr00089's Avatar
yup but i cant complain too much becuase i fixed my problem for free when i was expecting it too cost me like it usually does. 3 of my lug nuts were a quarter turn loose, but i guess thats all it takes to make some noise.
Old Aug 21, 2010 | 10:29 PM
EvolutinIX's Avatar
Everything at the stealership costs extra
jdogstoll23
May 9, 2016 09:34 AM
npham455
May 8, 2012 09:18 AM
racr00089
Aug 7, 2010 07:26 PM
ggevoIX
Apr 23, 2009 07:19 AM
steevo 8
Mar 11, 2009 07:50 PM
