Opinions on the best OEM intercooler replacement
Old Aug 22, 2010, 12:32 PM
hammerevo's Avatar
Hey guys, what intercoolers do you like that have the least modification to the car? I was looking at the Spearco kit that seems to be a direct replacement without needing a smaller battery or intake.
I run Time Trials and need to stay in the class I run, so I don't want to have to take additional points in classification by adding additional parts.
Thanks
Old Aug 22, 2010, 12:35 PM
grillpt's Avatar
CBRD, JMFab, Perrin, ETS... There all good and don't require much if any modification to install IIRC.
Old Aug 22, 2010, 12:40 PM
bbyevo8u's Avatar
ETS 3.5" or GARRETT 3.8"
Old Aug 22, 2010, 12:49 PM
4RETECH's Avatar
I like my ETS 3.5", but my old Buschur was amazingly light.
Cbrd And AMS get my nod too for a non mod intercooler.
Old Aug 22, 2010, 12:50 PM
hammerevo's Avatar
Thanks guys, I want to try to use factory mounting points as well.
Old Aug 22, 2010, 12:53 PM
tweaker41's Avatar
All those intercooler mentioned utilize the stock mounting points for installation.
Old Aug 22, 2010, 01:04 PM
sktng22's Avatar
i have an ams intercooler and love the thing. uses stock mounting points and u can buy the injen intercooler pipe kit wich wont require u to use a small battery kit.
Old Aug 22, 2010, 01:13 PM
Bigdezel502's Avatar
I have had the turbo xs intercooler and it worked great just had to get another 1 because it got cracked on a pot hole. I have the ams 1 now and I love it.
Old Aug 22, 2010, 01:20 PM
yahu's Avatar
I previously owned a Buschur and it seemed to hang a little lower than the others. I don't know if that was a design of an older version (this was in 2006) or if somehow I got it wrong (even though I did use all the stock mounting points).
I think the ETS 4" might even work like stock, but I'm not positive. the 3.5" does, and as someone else mentioned, you can't go wrong with a Garrett core (sold by a lot of vendors).
Old Aug 22, 2010, 01:27 PM
evo<3's Avatar
ETS!! just ordered mine waiting for it to come =] i know ill be happy
Old Aug 22, 2010, 01:30 PM
hammerevo's Avatar
Yeah, I think the CBRD IC uses a Garrett core as well. I had a little off-track adventure this weekend and bent a few things underneath, so lower hanging wouldn't be good either. The ams IC looks nice.
Old Aug 22, 2010, 03:13 PM
TommiM's Avatar
the endtanks on the ams look like a better design than some of the competitions, imo.
Old Aug 22, 2010, 03:27 PM
ssg_petty_210's Avatar
ETS intercooler, and you will be set. 3 or 3.5" requires no modification. Above that you lose your crash beam. The intercooler uses the stock mounting points. Price is great.
Old Aug 22, 2010, 03:41 PM
RockmanX's Avatar
wow nobody mentioned APS intercooler used stock mounting points and is 3.5 bar/plate design etc nice peace as well
Old Aug 22, 2010, 04:07 PM
TommiM's Avatar
AMS,AGP,APS are similar to each other. Looks like the APS will fit with the least modification then the AMS, then AGP. AGP, from what I read requires you to modify the undertray.
Quick Reply: Opinions on the best OEM intercooler replacement
