ACD Pump Dealer is Fighting warranty
I have an 05 with 52k miles. All three lights were on so I figured I would take it to the dealership to get it checked out. They called and said they cannot communicate with the ACD because of the aftermarket tune. Now I know this is not the case as the ACD has its own ECU which should be able to communicate just fine. They then said they thought that the cause of the pump failure was probably the high boost the car was seeing which I told them the two had no correlation whatsoever. Anyone have any further advice on how I can educate them that simple modifications have nothing to do with the ACD operation. The pump is supposed to be warrantied until 65k miles which I am well under. At this point they are not saying they will not warranty it but you can tell they are looking at reasons not too.
I had this same problem. Ended up buying a used low mileage ACE pump and installing it myself. Problem solved and I didn't have stealership r-tards working on or joy driving my car. Win win.
hpgirl
11
Jul 13, 2009 12:08 PM
