The car shakes when its cold
Old Feb 17, 2004 | 06:49 PM
Az3ar's Avatar
but hey its happens some times and some times it does not, by the way i live in OC it was 80 here today??
Old Feb 17, 2004 | 08:01 PM
Shahul X's Avatar
yea, im in mont co Maryland.... i got the chatters too....CM stage 3... it happens....
-shahul
Old Feb 18, 2004 | 01:11 AM
Thoe99's Avatar
Originally posted by inariv5573
Any car will shake more when you first start it when it's cold. Then it smooths out as it warms up. I kind of think of it as the car shivering before it warms up. I had a 69 chevelle for my first car and you could see the seats shake when it was cold.
My point was that it DID NOT happen before, and that this is something that developed over time.
Old Feb 29, 2004 | 09:36 PM
machron1's Avatar
It's clutch chatter
My clutch started to chatter when it was cold, then stopped after it was warm. This was when it had about 6K miles on it. Now it's getting toward 7K miles and it chatters all the time if i don't slip it at fairly high rpm, but it's worse when it's cold. This is normally a sign that the clutch is giving out and/or throwout bearing is wearing out and/or flywheel is warped, which _really_ sucks. I haven't ever drag raced my car and i haven't even had a good chance to drive it hard much considering it's been raining fairly constantly since I bought it in January. I think the clutch is just a piece of **** IMHO.
Old Feb 29, 2004 | 09:45 PM
Az3ar's Avatar
will thats what i thought. but the weird thing is it started doing this when the car had 6k for about 500 miles then, it stopped completly even when its cold???? so i was like whatever. now i moved to CA and the car has 11k and the hole thing started again all over???i think my clutch will die on the 20k mark which mitsu planned too. no hard feelings i knew that the clutch in this car is not top notch.
Old Feb 29, 2004 | 11:20 PM
SinCityEvo's Avatar
I have noticed this also when I drive off when the car is still cold. It shudders in 1st when slowly taking off, then after a few minutes, it's gone and smooth clutch engagement. From what I'm reading, it's normal. I only have 4k miles and no launches. I can't see the clutch going bad already. I thought symtoms of a bad clutch is RPMs building and not accelerating at the same rate usually felt in the upper gears and not 1st gear or 2nd. Correct me if I'm wrong.
Old Mar 1, 2004 | 07:12 AM
Az3ar's Avatar
its ganna do it more and more till you have to change your clutch
Old Jun 22, 2004 | 02:38 PM
blackevoVII's Avatar
Bringing back an oldie. Its Clutch Chatter. Its probably a bad spring or a plate bent. I have it too and it ****s with my first gear shifting...makes me nervous im going to get that obnoxious rumble.
Old Jun 22, 2004 | 02:42 PM
bryans2k's Avatar
similiar in nature:
https://www.evolutionm.net/forums/sh...ad.php?t=85358
Old Jun 22, 2004 | 02:52 PM
ColinL's Avatar
Originally Posted by Az3ar
it's gonna do it more and more till you have to change your clutch
correct. WRXs are plagued with clutch chatter, also.
get it warrantied if you can.
Old Jun 22, 2004 | 03:22 PM
Az3ar's Avatar
Now it happens with me everyday every hr. Worm or cold. I am sure its my clutch dying
TURBO_S2K
26
Dec 10, 2016 09:53 PM
Esvees
Apr 27, 2010 09:25 PM
mac214
Mar 18, 2009 10:02 PM
inariv5573
17
Jul 29, 2005 11:59 AM
TheBigLubinsky
Apr 29, 2005 04:47 PM
