2.3L 4g63 Stroker Questions (some new, some confirming)
#31
Interesting bit of something I ran into...
With an Exedy Twin Disk setup the flywheel bolts on fine, but there is actually a little bit of play around the center (raised) portion of the crank snout. It was a light press fit on the stock crank. Is this a normal occurance? Either way I'm going to make a little sleeve to get it to fit more like it did on the stock crank, but I feel like it probably doesn't need it - better to be safe I'm thinking...
#32
nice choice on the rods, I will be running Olivers in my 2.2 which Im building soon. The Manley's look like a nice rod but at 670 grams no way, overkill for a 35r.
#33
What pistons are you going to run? I was between the JEs and Wiseco HDs.
#35
That's interesting... is it the same material and just a thinner wall then? Or is it a different pin material entirely? Obviously it'd lead to weight redux - what sort of total weight change per pin?
R/TErnie
80
Jan 7, 2021 02:46 PM
Evo8Emperor
21
Nov 24, 2009 03:42 AM
