Grinding Into Reverse
Old Sep 27, 2010 | 08:00 PM
MR LuKe's Avatar
I just transfered over from the world of VW into a 06 evo mr. I love the car but i only have one complaint so far, When i start my car up on a cold start and go right to reverse it grinds. I have been just putting it in first and then into reverse and its fine but if there is a way to fix this i would like to know!! Can someone help please??
TIA
Old Sep 27, 2010 | 11:29 PM
EvoVIII808's Avatar
Sounds like syncro's going bad, try clutch peddle adjustment for now, but may need rebuild.
Old Sep 28, 2010 | 05:16 AM
MR LuKe's Avatar
The car only has 30k on it. I was hoping it was just something minor. I do still have warranty though so that'll be nice if its something serious
Old Sep 28, 2010 | 09:46 AM
MechTech's Avatar
push the clutch in and wait like 5 seconds then put it in reverse
Old Oct 3, 2010 | 02:04 PM
MR LuKe's Avatar
that did not work either, I am guessing i should just take advantage of my warranty while i have it
Old Oct 19, 2010 | 08:10 AM
rodent's Avatar
Sounds like your clutch is dragging. Is it hard to put in into gear? You can try to adjust the clutch. If that doesn't work, its new clutch time.
Old Oct 26, 2010 | 02:28 PM
gieri002's Avatar
It definitely is a syncro.
Old Oct 26, 2010 | 02:29 PM
gieri002's Avatar
Get in there before your warranty is up because it is a very expensive job!
Old Oct 26, 2010 | 03:01 PM
nonschlont's Avatar
Does it do this every time, or just every so often? Try putting it into first, first, then drop it into rev. and let it warm up a bit, dont just start it, and take off.
but ya, "synchros" are probobly going...
Old Oct 26, 2010 | 03:03 PM
mightybee's Avatar
Try changing out the fluids and see what happens, it might be your synchros but do a process of elimination 1st.
Old Oct 30, 2010 | 08:34 AM
xbeckk's Avatar
does it go into 1st easy first thing when it's cold?
drop it into 4th and then shift to reverse, does it go smooth into reverse then?
jakgal04
Jan 12, 2017 07:35 AM
evo82005!
Oct 13, 2015 07:21 AM
Luisito Chavez
Aug 16, 2013 10:22 AM
Braden71790
Apr 7, 2011 12:51 PM
s84kam
Lancer Tranny/Drivetrain Tech
Aug 25, 2009 11:31 AM
