Clutch problem?
Old Oct 1, 2010, 11:06 AM
06MRV8Killer's Avatar
^ I have heard from many reputable shops that the extension rod from lancershop will actually damage your clutch...
Also ACT clutches were or have been know for lock out issues.
Old Oct 1, 2010, 09:18 PM
MitsuJDM's Avatar
I actually adjusted the engagment point of the pedal closer to the floor just because it was high and the problem has not returned yet. Not saying this fixed it. I actually highly doubt it did anything. I'm starting to think it's more temp/fluid related. It has AMSoil 75w90 in for about 8k miles.
Old Oct 1, 2010, 09:35 PM
GR8WHITE RS's Avatar
did you check out the master cylinder or throw-out bearing? sometimes gearing it before taking off in the morning helps or even when you let it sit for awhile. try that.
Old Oct 5, 2010, 05:09 PM
suby2evo's Avatar
bump because I'm having this exact problem with my exedy twin disk! it's damn near impossible to put it into reverse. I literally turn my car of if I need to put my car into reverse.
Old Apr 25, 2012, 02:18 PM
SinisterEvoVIII's Avatar
I Got The Same Problem As Well In My 05 Evo VIII.... It's Hard To Put It In First In The Morning Or Reverse.... One Of My Friends Recommended I Run "Royal Purple" In It.... And After Reading Everything From Different Threads... Most Evo Owners Say It's Normal And Then Simply Switched Out The Fluid.... But I Havent Tryed It So I Wouldnt Know Exactly....
Old May 21, 2012, 11:04 PM
So Did Anyone Find Out The Cause Of Getting Locked Out Of 1st & Reverse Gear?
Old Feb 22, 2013, 10:27 PM
roszko's Avatar
thanks for the posts, helping a lot
Old Feb 23, 2013, 02:07 AM
akqowns's Avatar
You adjusted your pedal wrong. Not close to floor, you have to adjust exactly opposite. even If the height of your pedal bothers you that's just not correct way to adjust your clutch. If you adjust your clutch pedal rod shorter ( low pedal engagement ) you will have lock out issues and furthermore, you will end up destroy your clutch/ trans. It sounds like an engagement problem to me. Adjust your pedal higher and bleed your clutch. It also could be your pressure plate gone bad or possibly your clutch is time to replace even though there's no slippage.
jamaicaboost
Sep 28, 2016 11:55 PM
Fireescape
Jul 4, 2016 11:18 PM
quick4door
Jun 28, 2014 07:33 PM
deeman101
60
Jul 18, 2013 01:29 PM
MDEVO
30
May 16, 2005 04:56 PM
Quick Reply: Clutch problem?
