Setting Tru-Boost Duty Cycle
Old Oct 4, 2010 | 11:13 AM
SuperMoto!'s Avatar
When setting the duty cycle on an AEM Tru-Boost EBC, I assume this should be done while the car is under load (probably third gear), but I can niether confirm or deny these aligations. Could someone please shed some light on the subject?
Old Oct 5, 2010 | 10:22 PM
MasterNater's Avatar
Start with the duty cycle set as low as it will go, which I believe is 10%. Do a third gear pull to see how much boost you hit. Increase the duty cycle in small increments and keep doing pulls until you reach your desired boost pressure. There's a series of videos on youtube made by AEM that explains how to use the Tru-Boost. Just search YouTube for "AEM Tru Boost", if you need anymore help.
Old Oct 6, 2010 | 06:16 AM
SuperMoto!'s Avatar
Thanks for the reply, this helps a lot!
Old Oct 6, 2010 | 11:27 AM
omniprobe's Avatar
Set your spr before setting the duty cycles. You should to log it so you can see if boost is spiky.
fyreant
14
Sep 12, 2014 02:49 PM
raasfaas
16
Feb 13, 2009 04:58 AM
NJ_EveOhVIII
Oct 16, 2008 03:22 PM
Sicks
Sep 25, 2008 08:37 AM
EvoX_SA
Mar 5, 2008 03:54 PM
