Tomei arms m7960
Old Jul 16, 2014 | 04:52 AM
  #76
superkizuna's Avatar
You 'could' use the MBC to do this but you are preloading the crap out of your turbo and you have your MBC all turned up and there is no increase in boost...... are you using the Tomei Arms? Is this a stocker? What's up?
Old Jul 16, 2014 | 07:13 AM
  #77
selp's Avatar
I have a built 2.3L with a 9.0:1 Compression. JE Pistons, I Beam Turbo Tuffs, etc etc.
I want to say the WGA was preloaded to what everyone recommends, maybe a little bit more (The rod will need to be pulled over the pin so that 1/4" of the hole on the rod is covered. 3/4" of the rod should be empty). So the WGa spring is 23 psi, and the car is boosting 25psi with just the WGA. Once I add the Boost Controller, turned all the way (high boost), I only get an increase of 3-4psi max.
I keep scratching my head, but I think it might be the spring on the boost controller is no longer holding, so either change the boost controller or change the spring.
Also, hypotetically speaking, if I was to preload the wga more than the "recommended" what could happen? can the flapper be bent? damaged?
Thanks
Regards
Old Jul 28, 2014 | 01:46 AM
  #78
_evo9's Avatar
Hi there,
I thought i’d add my results with this turbo. I’ve had it since new ( 1st edition )
Attached Thumbnails Tomei arms m7960-10521217_10152642041904369_1130506653_n-1.jpg
Randal
E85 / Ethanol
29
Jan 19, 2015 07:06 PM
hung861988
Nov 15, 2014 02:54 PM
andru38
Nov 8, 2013 07:56 PM
Randal
15
Aug 30, 2013 08:39 AM
Randal
39
Sep 24, 2012 12:10 AM
