Car won't fire
Old Oct 6, 2010 | 05:40 PM
birdhead's Avatar
Car won't fire
We just put a new head gasket and headstuds in. We are getting fuel but won't fire we put net coils on it still no. It's weird the engine is timed right too. Please help o it is 2.3 strocker with a gt42r turbo and it has aem ecu
Old Oct 6, 2010 | 06:21 PM
MRolla's Avatar
cam sensor reading? is the crank reading the reluctor ring, reluctor ring installed. are you getting sprak?. are all fuses good?
Old Oct 6, 2010 | 06:31 PM
Force-Fed Performance's Avatar
you may need to provide a lil more information so people can help or give advice buddy.
Have to tested compression, was the car running fine before? Was the head re-surfaced before it was installed?
Old Oct 6, 2010 | 08:42 PM
signature sound's Avatar
make sure the crank position sensor plate is on in the right direction. flipping it 180* could cause this.
Old Oct 6, 2010 | 10:16 PM
birdhead's Avatar
Yea every thing is on right the car was running before
Old Oct 7, 2010 | 12:04 AM
EvoVIII808's Avatar
Fuses, CAS, and was this a plug n play EMS or universal? Could have some wires mixed up if universal.
Old Oct 7, 2010 | 11:09 AM
birdhead's Avatar
It's a plug in play the cas is good I have checked everything
Old Oct 7, 2010 | 12:46 PM
05VIII's Avatar
You checked everything? Obviously not if it still won't start. Go back and check fuses and sensors, one has to be bad.
Old Oct 7, 2010 | 02:08 PM
EvoVIII808's Avatar
Not sure if the Question of Are you getting spark was answered.
Need to pull those plugs/coils and check. Car Ran fine before a head swap, there has to be a connection not connected or blown fuse somewhere.
Old Oct 7, 2010 | 03:32 PM
birdhead's Avatar
I've checked the fuses again connectors I even changed plugs and coils to
Old Oct 7, 2010 | 05:37 PM
NJ_EveOhVIII's Avatar
prob some ground you missed or a little sensor.
or its just your car being mad at you that it will only be in full boost for maybe 2k rpm.
Old Oct 7, 2010 | 05:55 PM
EvoVIII808's Avatar
lol.
Old Oct 9, 2010 | 08:31 PM
JonDSM's Avatar
Is the check engine light on? can you scan it and just have the computer tell you what's wrong?
Do you have a test lead to hook up a timing light and check your ignition timing?
Are all your grounds hooked up?
Old Oct 26, 2010 | 01:58 PM
gieri002's Avatar
Are you sure the oil pump pulley is not rotated 180 degrees?
gieri002's Avatar
Did it run before?
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
Evo_8_power
Jun 22, 2017 04:11 PM
2006GSR
20
Mar 13, 2017 11:33 AM
TxFAkuma
Oct 22, 2015 09:11 PM
joehaugen
Oct 3, 2015 03:40 PM
