Converting T-Case to FWD
Old Feb 5, 2011 | 09:12 AM
Alchem1st's Avatar
Yeah, you can weld it solid.
Old Feb 5, 2011 | 09:33 AM
Izerous's Avatar
In theory might also be able to pull a tranny from a fwd Outty not just a RA, unless the tranny is different but I thought they were the same. 03's used 4G63s and the other first gens used 4G69s so it gives you a couple more options.
Old Jun 9, 2012 | 08:37 AM
BrunoBoy650's Avatar
bumping you guys, so did the RA trans work?
Old Jun 9, 2012 | 09:35 AM
Migsubishi's Avatar
Man just wait till you can put a rear in it, these parts are to expensive to butcher. I know what your going through. I put an AWD rear end into a civic and that car was fun.
Old Apr 24, 2013 | 01:35 PM
Robin651's Avatar
Old thread back from the dead!
So from my research what I've gathered is you lock the center diff via welding it, and you cap off the output on the Transfer case, either by fabbing a block-off plate, or welding it shut completely. Am I correct?
Can you just put an a limited slip center diff instead of welding it?
My assumption of the locked center diff is that I am led to believe that it's not as easy as blocking the output shaft on the t-case and rolling fwd as you would burn up the viscous coupler (center diff). Is that correct?
Brandon Blank
Jan 20, 2016 02:56 PM
Live4Redline
Jun 7, 2012 03:18 AM
VTEC Killer
39
Apr 17, 2009 09:32 PM
Disruptorzero
Dec 8, 2008 05:54 PM
Bladed
Lancer Tranny/Drivetrain Tech
23
Mar 4, 2008 07:52 PM
