Bad lifter? Something else?
Old Oct 14, 2010 | 06:23 PM
evojoe90's Avatar
almost 100 percent its a lifter. i had same exact noise. and to fix it i put in jam non-ticking lifters lol sound like a bunch of bs but deff worth every penny
Old Oct 14, 2010 | 08:24 PM
TJSAP00's Avatar
Thanks for the less stressful opinion lol. Are these them right here?
http://jacksonautomachine.com/index....mart&Itemid=12
Old Oct 15, 2010 | 06:40 AM
tony gibson's Avatar
I have a similar prob right now. Put in a 2.3 stroker and the noise started like a month after....so obviously I pulled the pan and the rod bearings were beautiful...looked just the way they did when installed. The noise is definitely coming from the head but upon inspection, nothing is visibly wrong including rollers..I'm at a loss. Replaced the lifters with 1g lifters on the number 1 cylinder which is where I pinpointed the noise and no help. the noise is coming from the front timing belt side of the head... Whatever just drive it til it breaks. thats my theory ever since I figured out it wasn't the bottom end.
Old Oct 16, 2010 | 05:34 PM
evojoe90's Avatar
yup those are it..id say give it a shot. it worked for me, just follow the instructions and you should be tick free.
Old Oct 16, 2010 | 05:43 PM
tscompusa2's Avatar
make another video reving it higher quicker and letting off.. ill tell you if its a lash adjuster or a rod knock. if you didnt let the motor run low on oil its not likely rod knock.
Old Oct 17, 2010 | 02:39 PM
TJSAP00's Avatar
Here is the scoop, finally got working on the car today with a buddy, it is definitely not a spun bearing. We took everything off, took out the lifters and bleed all 16. When we started up the car seemed like every single one was ticking so it sounded like a gatling gun. After letting it idle and what not seemed like most of them filled back up. There is still ticking, so I assume it is 1 or maybe 2 lifters that have seized and/or busted. Im guessing ill order the new lifters and try those out. Thanks for all the inquires and comments. Ill keep everyone updated.
Old Oct 17, 2010 | 02:42 PM
tscompusa2's Avatar
i bet you're happy it wasnt the rod bearing.
as for the ticking like crazy its normal. start the car up let it get to running temp and then rev it and hold the rpm to 3500 rpm for 15 seconds then let off.. and repeat this about 10-15 times until the ticks are all gone this is documented in the service bulletins and this is how you fill the lash adjusters back up.
ADD:
btw if you bled them all and didnt notice anything weird with any, then chances are they are all fine. just do what i mentioned above and you should be tick free.
Old Oct 18, 2010 | 02:05 AM
crckheadjed's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=517001
Identical problem, I've replaced lifters, swapped out injectors, undid the vacuum line to the pcv and that wasn't it. Haven't pulled pan yet but its quiet under the car really sounds like its on top. Hopefully I can figure something out, let me know how things go for you.
Old Oct 18, 2010 | 08:14 AM
TJSAP00's Avatar
Thats exactly what mine sounded like, my phone took a crappy video audio wise so it sounded a lot worse.
Old Dec 27, 2011 | 08:12 AM
My03evo's Avatar
Crckhead and tjsapoo....did you ever figure out the noise? Mine has the exact same noise which started after a 2nd gear pull....What was wrong with yours?? Yes I know it's an old thread sorry but better than making a new one
Old Dec 27, 2011 | 09:39 AM
dastallion951's Avatar
well if its still making ticking noises and goes up with rpms somewhat, yet its not a lifter or spun bearings, id be more inclined to look at your serp belt tensioner, or possibly one of the pullies as a suggestion. Sometimes a pulley going bad can make some ticking style noises, which under right load can make it sound similar to a lifter tick.
Ian0611
16
Sep 27, 2023 01:42 PM
Hassan
103
Aug 5, 2023 11:37 AM
skans789
Oct 16, 2009 02:49 AM
NJ_EveOhVIII
Jan 30, 2009 06:39 AM
Kierkegaard
Nov 20, 2007 08:04 AM
