GTII 7460R vs BBK Full photo shoot
Old Oct 27, 2010 | 07:38 PM
  #91
06MREvo's Avatar
Originally Posted by CBRD
My 125cc Shifter Kart may end up with a small IHI turbo on it... then i start the whole cycle again
cb
hahaha...that would be ridiculous...I would pay to drive that thing...
Old Oct 28, 2010 | 05:50 AM
  #92
CBRD's Avatar
yeah sorry to take this off topic,
just re-read this morning
look forward to results!
cb
Old Oct 28, 2010 | 05:59 AM
  #93
XSivPSI's Avatar
subscribed.
Old Oct 28, 2010 | 06:26 AM
  #94
SPANKED's Avatar
Chad what is your opinion on the new grind on the HKS cams? Would you go with S2s instead?
Old Oct 28, 2010 | 06:46 AM
  #95
CBRD's Avatar
I honestly dont know!
If someone would bring a car to me with the HKS turbo and cams I'd love to give some feedback!
I havent had a chance,
the S2's are a great cam, and we use MANY of them...
Maybe R/T or someone else has some input!
cb
Old Oct 28, 2010 | 06:53 AM
  #96
R/TErnie's Avatar
I don't know for sure, but I'm sure they're not far from their original 272's, yet still not as aggressive as an s2. We would need to know the lift at .050 and look at the ramp profiles to get a better idea... And furthermore dyno testing.
Old Oct 28, 2010 | 09:29 AM
  #97
mrfred's Avatar
Originally Posted by dbsears
In for results! I was just in Tri-cities not too long ago mrfred. Happen to have a friend that just moved over there so I will make the trek more often. Didn't see too many evo's while I was there though.
I think there are around 10 Evos in the Tri-Cities. I know three well - droppinbottom (10), 3man1 (10), and uvambo (9). None of the others I've seen ever seem to post on EvoM. Drop me a PM next time you are planning to head over there.
Old Oct 28, 2010 | 09:39 AM
  #98
mrfred's Avatar
Aaron (JB) did a quick comparison with S2s. They are pretty close. I think the intake has about 0.4 mm less lift, and there may be slightly less duration. I'll get the specs from him as I'm interested too.
Old Oct 28, 2010 | 09:51 AM
  #99
R/TErnie's Avatar
A lathe and a dial indicator work pretty well. then you just have to multiply your lift by the variable rocker arm ratio and account for the point of contact with the roller rocker. LOL.
but yeah if you did both of them on the same lathe without applying kinematics, then yeah you could get a pretty good idea of what was going on.
*or a really simple way* replace the valve spring with a soft spring and measure the lift degree by degree directly at the valve with a dial indiciator. :P
Old Oct 28, 2010 | 11:59 AM
  #100
shuttlegoose's Avatar
what ever happened to results???
Old Oct 28, 2010 | 12:44 PM
  #101
mrfred's Avatar
Patience. All this work takes time. BBK + ToxicFab is on the car and tuning is in progress. Next phase (manifold and turbo comparison) is next week.
Old Oct 28, 2010 | 01:02 PM
  #102
CBRD's Avatar
MRFRED,
cant remember, did you get the turbo from us? or used from someone else? curious also if its ported! and running our actuator!
cb
Old Oct 28, 2010 | 01:06 PM
  #103
ToxicFab's Avatar
MRFRED,
cb
I believe on the first page with pics it is ported. Can't wait
Old Oct 28, 2010 | 01:26 PM
  #104
SPANKED's Avatar
Not sure what that amounts to on the dyno but if they are close to the S2s then maybe I'll stick with them instead of selling them for S2s...
Old Oct 28, 2010 | 01:29 PM
  #105
tvbf1's Avatar
I'm more keen on knowing what's the spool like on the HKS turbo. I can care less on the top end power (if the difference isn't to much that is). More interesting for me is how much faster the turbo spools in the low and mid range. Be awesome if the Tomei was on the testing chart as well. But beggers can't be choosey, so I'll take what I can get.
