Supertech spring retainer kit vs gsc spring retainer kit??
Old Oct 15, 2010 | 06:46 PM
toysgetsmoked's Avatar
Trying to choose a spring retainer kit cause Im having valve flutter and some valve float..My choose is between supertech dual valve spring kit or the gsc spring kit ??Im using gsc2 cams with 6262 TURBO..
Old Oct 15, 2010 | 06:58 PM
Originally Posted by domoing
IMO, i would go with the Supertech DUal Valve Springs.
Any experience with them??
Old Oct 15, 2010 | 07:14 PM
AWD Motorsports's Avatar
I would use the GSC Spring retainer kit.. The 5041 kit with Springs, Retainers and Seats is what you need for your setup.. I like the GSC because the retainers are SUPER LIGHT!!!
If you need a set PM me.. Thanks!!
Mike
BoostWhore's Avatar
how do you know your having valve float?
Old Oct 15, 2010 | 07:17 PM
Originally Posted by BoostWhore
how do you know your having valve float... normally that will cause engine damage. It really depends what your plans are for your car and how high you want to rev it.
It does not cause engine damage normally.. Its easy to spot as well.. There will be a drop in power right where it hits peak TQ usually or a set RPM.. its easy to hear also if you know what your listening for..
Mike
Old Oct 15, 2010 | 07:50 PM
I keep hearing great things about the supertech kit buschur uses them in his stage 3 heads..What does lighter retainers do??
Mike
Mike
Exactly mike just the power drops and motor picks up lots of knock do to the stock springs..I then I wondered why I didn't make lots of power of the stock sticks.
Old Oct 16, 2010 | 07:11 AM
Anyone else about what kit to choose??
Old Oct 16, 2010 | 12:11 PM
cssaddictm4's Avatar
Both are great kits, and have proven themselves time and time again. It probably will come down to the price, and if you can get a deal on one.
Old Oct 17, 2010 | 11:01 AM
DOUGLAS's Avatar
I went with the Supertech as they ended up being cheaper and they are just as proven. You have to do some actual research if you do not want to be swayed by shops bias or want to sell a product.
Sheasta
Oct 21, 2015 03:28 PM
four-loco
45
Jun 26, 2013 09:26 AM
ohmohm
Jun 10, 2013 09:04 AM
jnut24
Northwest Region
14
Oct 11, 2011 08:36 AM
LapDance
14
Dec 22, 2010 08:21 PM
