2.1 destroked or 2.4 stroker?
Old Oct 25, 2010 | 01:13 PM
  #31
ChrisCarey's Avatar
Originally Posted by miragevo
Chris, Wiseco's catalog shows the 1400hd 9.7:1 piston in the K626, but not in the stroker design K627. You will need the pin shifted up 6mm to run your 156mm rod in a 2.4 Long Rod motor.....I know you knew this already, but was just clarifiying. Can you give a few more details and a link to the part you're selling?
The 2.1L uses the K626 pistons, but you are correct the LR2.4 would be a custom bore of the K627 so essentially you could have them built in whatever CR you desire
Old Oct 25, 2010 | 01:33 PM
  #32
miragevo's Avatar
Veteran: Navy
Chris, you are building the 4G64 2.1 liter using the K626 standard compression height piston and a custom 156mm rod? Why not use the K627 stroker piston that shifts the pin up 6mm and will be a lighter piston to reduce the rotating mass. This standard style stroker piston that many manufacturers sell has been proven to handle the power with cars running in the low 9's....etc. Make a custom 162mm version of your rod and you will increase the rod stroke ratio from 1.77 to 1.84 to boot. So, with an 87mm bore version of the K627 stroker 1400HD piston @ 9.7:1 and a custom 162mm length version of your Connecting Rod built in a 4G64 you would net 2093cc ~ 2.1 Liter
Any weights on the 156mm rod?
Old Oct 25, 2010 | 06:35 PM
  #33
Alexl08's Avatar
i need to read up more about this
Old Oct 25, 2010 | 08:34 PM
  #34
RockmanX's Avatar
2.4 yes sir!!!!!!!!! ALL DAY EVERYDAY
Old Oct 25, 2010 | 10:10 PM
  #35
Midnightevo8's Avatar
Looks like the 2.4 is the way to go...
Old Oct 26, 2010 | 12:05 AM
  #36
wreckless969's Avatar
I like the 2.4 but for some reason the purest in me wanted to keep the block a 4g63 block...it's a semi motor swap for the Galant engine and I can't look past that. Maybe for the wife's Evo
Old Oct 26, 2010 | 08:11 AM
  #37
ChrisCarey's Avatar
The main reasoning is that the rods need to be made in quantity to be cost effective, and then you have to add in the cost of custom pistons. The rod ratio of the 156mm 2.1L is superb and most people won't even be able to take full advantage of that let alone a 162mm rod
Old Oct 26, 2010 | 02:21 PM
  #38
Does the 2.4 sound any different?
Old Oct 26, 2010 | 03:10 PM
  #39
RockmanX's Avatar
haaaaaaaaaaaa funny question click on my monster video in my sig inf you wanna hear and see a 2.4 in action but sound mostly in your cams tune and exhaust system boss
Old Oct 26, 2010 | 03:28 PM
  #40
When I bought the car it came with hks 272's and I have 3" tbe with a dump and no cat
Old Oct 26, 2010 | 03:38 PM
  #41
I was running HKS 272's and a TBE with no cat and my car sounds so much better being a stroker...different cams but same exhaust. The tone is much deeper, I can park at the back of the walmart parking lot and still here the low frequency grumble al lthe way to the doors. It's badass.
Old Oct 27, 2010 | 08:14 AM
  #42
That definitley sounds deeper...also that's a clean car man! I love the blue Evos. I think I'm going to get a 4g64 crank from Awd motorsports there I think $225 shipped.
Old Oct 27, 2010 | 09:01 AM
  #43
RockmanX's Avatar
incorrect they are 200 shipped unless mike raised his prices I bought a crank from him
Old Oct 31, 2010 | 08:35 AM
  #44
RunThat's Avatar
Now I can't decide on the 2.1 or 2.4!!! I just got the CBRD BBK-B turbo, but sometime next year I am planning on getting one of the new Full-Race EFR T4 TS setups. I was going to get the 2.1L considering the big turbo setup for next year, but then again, the 2.4 will spool it faster. Then again, I CAN rev it to the moon with the 2.1L which is good since the big turbo setup will boost up there. Any thoughts?
Old Oct 31, 2010 | 08:54 AM
  #45
240sxzenki's Avatar
yep higher rev on the 2.1 more fun
