overheating problems
Old Nov 5, 2010 | 12:53 PM
aalleyboy's Avatar
hey guys am new to the forum recently bought an evo 8 .so this is my story bought an evo 8 rebuild rebuild the bottom end with manley rod an weisco piston changed all valves an put back together.the problem is the fan is acting weird by coming on an of really fast plus over heats on idle for like 10 to 15 minutes but when driving it works fine never really got on boost as yet because am breaking in the motor the car is run by aem .can some of u evo guys out there assist me with some ideas on what to do thanks.everything on the car is stock .
Old Nov 5, 2010 | 02:02 PM
Ev0ikon's Avatar
Are you sure the Thermostat is good?
Old Nov 5, 2010 | 03:11 PM
cssaddictm4's Avatar
Punctuation my friend...that hurts to read.
Bleed the coolant system?
Was a new water pump installed?
Any leaks?
Test the fan control module?
What temperature are you seeing in AEMPro when it is overheating?
What AFR/timing are you running at idle?
Pressure test the system and/or smoke test it.
Mauricio Evo IV
11
Oct 31, 2017 12:10 AM
evo8tanner
Jun 14, 2017 11:12 AM
danny_6725
Mar 17, 2015 07:57 AM
DanDan1320
Feb 21, 2013 12:16 PM
mimmo124
Australian Forum
11
Aug 24, 2003 07:24 PM
