Anybody port/polish turbo, O2, exh
Old Dec 4, 2003 | 07:50 PM
  #31
bishiboy's Avatar
Close up of Wastegate outlet
Attached Thumbnails Anybody port/polish turbo, O2, exh-woutlet.jpg
Old Dec 4, 2003 | 07:52 PM
  #32
5StarSuzuki's Avatar
In Timeout
Take a picture of the equipment your using to polish... thanks!
Old Dec 4, 2003 | 08:01 PM
  #33
bishiboy's Avatar
5Star, here you go, It's a Crafstman Die Grinder kit and a DIY Port and Polish kit from my local speed shop (cartridge rolls with flapper wheel).
I used this site as a guide:
http://www.sa-motorsports.com/diyport.htm
Attached Thumbnails Anybody port/polish turbo, O2, exh-grinder.jpg
Old Dec 4, 2003 | 08:02 PM
  #34
bishiboy's Avatar
Port and Polish kit
Attached Thumbnails Anybody port/polish turbo, O2, exh-rolls.jpg
Old Dec 5, 2003 | 02:40 PM
  #35
David Buschur's Avatar
I am not being negative here, just giving more advise to anyone that wants it.
See that pretty polish you put on that cast iron? Going to be fairly rough again about 2 minutes after the car is running. Don't waste your time polishing exhaust components. The carbon builds up so fast it just gets back to being rough again. The stones you have pictured in your kit about will be all that is needed for a final finish on the port work. Save yourself time and money for the sanding roles, you really don't need to polish the exhaust components.
David Buschur
www.buschurracing.com
Old Dec 6, 2003 | 08:25 AM
  #36
robert5995's Avatar
Originally posted by bpclements
So that manifold will work on the stock turbo?
That's what they tell me. Nice, huh?
Old Dec 6, 2003 | 05:04 PM
  #37
bpclements's Avatar
That would be awesome. So, you could upgrade your manifold, run the stock turbo, and then later throw the turbo upgrade on there.
Old Dec 6, 2003 | 05:19 PM
  #38
robert5995's Avatar
Or, Mr. bpclements, you port match _that_ manifold, grind out the casting flaws, and bolt the thing right on. Better airflow, indeed. Turbo car efficiency and responsiveness is all about reducing restrictions, especially here in the Rockies where we're all at 5400' above sea level minimum. Did you check out the APS intake manifold? It makes me weak just looking at it!
Old Dec 6, 2003 | 05:28 PM
  #39
ShapeGSX's Avatar
Personally, I don't think that exhaust manifold porting or turbo porting does much. The ports are bigger than the combined area of 2 valves. And there are only ever 2 valves open at a single time. Same goes for the throat of the turbine housing.
Old Dec 6, 2003 | 05:35 PM
  #40
robert5995's Avatar
Josh -
YOu are right in spirit. Yet if the exhaust is mismatched, or offset from the port, you're creating turbulence when you really want nice, laminar airflow. Maybe I should have spoken more strongly of "port matching" instead of porting, which is generally a waste of time on a turbo car. I'd think there would be nothing wrong with removing casting lines, since the manufacturer would remove them if they could justify the $, which they can't. I can, since I only have to do one car. Also, keep in mind that the port cross-sectional area should be at least as large as the circumference of the valve times the max. lift, times the number of valves.
Old Dec 6, 2003 | 05:49 PM
  #41
ShapeGSX's Avatar
Oh yeah, turbulence is definitley worth getting rid of.
Old Dec 6, 2003 | 05:57 PM
  #42
ShapeGSX's Avatar
Oh, but note that the exhaust manifold runners should be larger than the head ports to prevent reversion. Not too large, though, otherwise you kill exhaust velocity.
Old Dec 6, 2003 | 06:07 PM
  #43
robert5995's Avatar
Josh, you're a smart man. Something you touched on is this: one thing we Evo owners don't have to worry about is exhaust scavenging, which has eaten up zillions of engineering hours. I had to do a bunch of research before buying one particular tube header for my '73 BMW 2002. All we have to worry about is delivering the most kinetic and thermal energy to the turbo in the most efficient manner. That's where I get stoked over the APS exhaust manifold. They're only selling the thing as part of their entire system - intake, exhaust, turbo, intercooler, piping - the whole deal. Too bad for us!
clip14
Aug 30, 2016 07:18 AM
Magiken
For Sale - Cars For Sale
Jul 19, 2016 03:49 PM
kaj
56
Aug 5, 2015 03:20 PM
black_beauty
21
May 20, 2015 02:11 AM
rory_j13
04-06 Lancer Ralliart How To Requests / Questions / Tips
May 10, 2010 06:32 AM
