for anyone that has crankcase pressure issues
Old Jul 20, 2014 | 03:28 PM
  #946
211Ratsbud's Avatar
Picked up as pierburg piece from a 11' Chevy . This moves some air . Someday I will put it on ...lol
Old Jul 20, 2014 | 04:27 PM
  #947
mrfred's Avatar
is this a smog pump?
Old Jul 20, 2014 | 10:46 PM
  #948
TommiM's Avatar
So I read through a lot of this thread but not all of it. Maybe I missed it, but has anyone considered running that balance shaft inspection breather line up to the intake to help scavenge some crankcase pressures??
Old Jul 21, 2014 | 07:14 PM
  #949
TheBigD's Avatar
No but I run the one out the balance shift hole itself and that moves air
Old Jul 24, 2014 | 10:00 AM
  #950
silver9mr's Avatar
I heard that running a VTA style oil catch can that it can cause crank case pressure and possible cause some oil burning. I have the buschur oil catch can on my 9 and every once in a while after driving and coming to a stop ill have a little smoke come from the exhaust.
Iv been having the issue of burning oil and the block has less than 5k on it, less than 2k on the turbo and the valve seals were replaced just 500 miles ago. still blue smoke when coming to s a stop, its making me crazy. I refuse to believe my rings are bad. could putting the pcv valve back in and using the IM again work?
Old Jul 25, 2014 | 09:31 PM
  #951
mattyboost's Avatar
I got a chance to hook up my sealed catch can and drive the car and it resolved all of my issues with my ball bearing fp red. those of which caused the car to smoke on WOT and to leak oil into the compressor housing
Old Jul 26, 2014 | 05:04 AM
  #952
Dragracer187's Avatar
post pictures of your catchcan
Old Jul 26, 2014 | 08:41 AM
  #953
mrfred's Avatar
I'm curious to see as well too.
Old Jul 26, 2014 | 12:05 PM
  #954
mattyboost's Avatar
2x -10an fittings in the valve cover to a sealed can with a -12an fitting going to the intake to pull vacuum
Attached Thumbnails for anyone that has crankcase pressure issues-img_8961.jpg
Old Jul 29, 2014 | 07:29 AM
  #955
pupo's Avatar
What about the PCV side port, did you delete / plugged that side?
Old Jul 29, 2014 | 04:31 PM
  #956
mattyboost's Avatar
i kept the pcv valve because fp recommended I do so and everything works fine
Old Jul 29, 2014 | 05:54 PM
  #957
mrfred's Avatar
Would be interesting to see what level of vacuum is being generated at the connection to the intake pipe. I measured almost 4 psi of vacuum when running MAF, but I haven't measured the vacuum with a speed density setup. I have been assuming that it would be in the range of 0.5-1 psi of vacuum which doesn't seem like much.
Old Jul 29, 2014 | 06:04 PM
  #958
Blue91lx's Avatar
Weird, I run two -10s from the head (no PCV) and a -6 from the BSI plug all to a vented catch can with no adverse effects, no smoke, etc.
It also solved my dipstick blowing out issue, and collects moisture just fine.
Old Jul 30, 2014 | 03:53 AM
  #959
tscompusa's Avatar
I got a cool catch can yesterday from Radium for my blue evo since im a dealer for them. I'm gonna post a little bit of pics of it in here when i get some free time.
But from just quick inspection, the catch can is of awesome quality. it has a little dipstick built into it that you screw in and pull out to check the level of the oil in the can. I don't know the history of this company, but it seems like their products are very high quality.
Everything's Billet. And build quality seemed amazing.
http://www.radiumauto.com/Catch-Can-...I-IX-P385.aspx
Is what I'm referring to.
Old Jul 30, 2014 | 11:46 AM
  #960
WannaRace's Avatar
^Running this set up for the past 3 months. Looks great and functions perfectly. Dipsticks are very useful for gauging how much blow-by has accumulated.
I've only got it set up with factory hose routing right now but I don't have any crankcase pressure issues at the moment. Radium makes it very easy to change all fittings and lines to accommodate any -AN fitting. Very slick setup! Here's my personal car:
