for anyone that has crankcase pressure issues
Old Jul 31, 2015 | 09:39 PM
  #1126
kaj's Avatar
kaj
Originally Posted by mrfred
Only the PCV valve flow that Tee's off the -10 AN line will go into the IM. The -10 AN needs to VTA or go into the intake pipe.
Ooooh. A "T". Now it makes sense.
Old Aug 4, 2015 | 06:24 PM
  #1127
Erik@MIL.SPEC's Avatar
If I delete the EGR valve and have my head guy weld over the EGR hole on the exhaust side and plug the intake side EGR port on the head, do I even need to worry about the rear vent on the valve cover? I could just have both the side vent and the rear go to a single catch can and pull vacuum off the intake? Correct?
Old Aug 4, 2015 | 09:20 PM
  #1128
LetsGetThisDone's Avatar
No, you only get vacuum on throttle that way. You want to use the PCV to generate vacuum while off throttle.
Old Aug 7, 2015 | 04:18 AM
  #1129
Dragracer187's Avatar
What about this idea, putting fuel cell foam in the valvecover:
Or instead of putting it in the camcover put it in the catchcan?
Complete article here: http://run-it-hard.com/2013/03/contr...thing-part-ii/
Old Aug 7, 2015 | 06:25 AM
  #1130
honda-guy's Avatar
are those rated for high temp? since fuel cell don't get that hot.
Old Aug 7, 2015 | 06:52 AM
  #1131
dsm nexus's Avatar
I would be concerned about it acting like a sponge, or is it more like the properties of steel wool?
Old Aug 7, 2015 | 07:10 AM
  #1132
If it would act like a sponge how can they fill a fuel tank with 80% if this foam. That would not work.
This kind of foam is also used on many bikes as part of the crank ventilation system.
Old Aug 7, 2015 | 07:14 AM
  #1133
dsm nexus's Avatar
What is the purpose of the foam in a fuel cell? Looks more like mesh then foam. Was assuming sponge from the name. People have been using steel wool inside the catch cans to separate the oil and water from the air. It may have a use there, not sure how it would do inside the valve cover.
Old Aug 7, 2015 | 07:35 AM
  #1134
Foam in a cell keeps the fuel from sloshing so you don't need to run baffles. The stuff is highly porous. It would really help condense the oil out of the air.
But, I don't see the point of this. I barely get any oil out of either valve cover fitting.
Old Aug 7, 2015 | 07:41 AM
  #1135
The normal purpose is to combat fuel surge and safety for explosions when the fuel cell ruptures in a accident. I would not use it in a valve cover, although it is possible, I might try it in the catchtank. You can fill the whole catchtank with it. I think it will help a lot seperating oil from the air.
Old Aug 7, 2015 | 08:21 AM
  #1136
dsm nexus's Avatar
Since I vented my rear port to atmosphere it has had about 1/3 quart show up in my catch can over the last 30-40 pulls or so. Front right has no oil, just a tiny amount of moisture from the humidity.
Would you use this with a baffled or non baffled catch can?
Old Aug 7, 2015 | 09:23 AM
  #1137
Or put it in the valve cover where it will also separate oil from air and less oil gets to the catch can. Fuel cell foam is silicone foam, so even though I haven't been able to find a temp rating, I'm sure its good for at least 300*, which is fine for oil in the valvecover. I would probably replace it semi frequently to to prevent it from falling apart and going into the motor.
Old Aug 7, 2015 | 10:18 PM
  #1138
kaj's Avatar
kaj
How would you attach it?
Old Aug 10, 2015 | 09:16 AM
  #1139
You put the plate back over it and it won't go anywhere.
Old Aug 18, 2015 | 12:55 AM
  #1140
N3WBI3's Avatar
@mrfred @letsgetthisdone
With the radium crankcase vent, can that be vta and still be routed to the intake pipe or just vta? Same or different on the pcv side? I ordered the STM -10 for pcv and -6 for drivers side on the vc. Removed the baffles but there is nothing more confusing to me than a proper pcv catch can setup and I have no idea why. I've read a ton of this thread and there's so many variances of setups its border line overwhelming.
