winter Project ''project 9'' by Evodan2004.
Old Dec 19, 2010 | 12:31 PM
  #76
tscompusa2's Avatar
Originally Posted by n2oiroc
pb blaster is decent for something you can easily buy. its better than wd40 and liquid wrench but its still kinda oily. aerokroil is much lighter in viscosity, thinner than water it seems and creeps into places the thicker ones cant. aerokroil just works a lot better but its hard to find. you can get it on amazon and ebay and some specialty stores though.
risk free trial here if you want to give it a shot.
https://secure.concentric.com/kanola...er_kroil.shtml
good info thanks man. so would this be a good comparison then? pb blaster vs aerokroil is like comparing wd40 to brake cleaner when cleaning out metal shavings and etc? is it that extreme of a difference?
Old Dec 19, 2010 | 12:38 PM
  #77
EvoDan2004's Avatar
Originally Posted by tscompusa
ya we were trying to troubleshoot Daves car, he was experiencing a misfire uptop and his car in general has a lot of phantom knock. got rid of the phantom knock, but was experiencing some weird stuff with his car for sure tuning wise.. turns out he needs new coils. he said hes pm'ing you to get ahold of sparktech for him. i told him id sell him my old coils since they were completely fine but i have a evo 8 and he is a 9 but i read they can be used on the 9 if the boots are swapped is this correct? if so ill give him my old coils for very cheap.
i had him check the timing on the gears/crank etc, because ive experienced a issue similar on another customer but everything checked out perfect. i asked him who did his work he said you so i figured id put it up here :P If you want, anyone i tune in your area i can refer them to you if you want the business for bolt on / maintenance work etc.
im sure i can get a lot of work thrown your way. turbo installs, injectors, etc.. easy stuff.
if ER cant find your rear subframe maybe mike@awd has something?
Mike is pretty good to me and he was the first person I asked. He didn't have anything.
The Evo 8 and 9 coils are the same just swap out the boots. Im pretty sure his timing is spot on. We double checked it and rotated the motor by hand and checked again. As I do with every car. If for some reason its off send him back as I will fix it. I back up my work if I mad a mistake. He has m3 cams in that car. And a qm clutch. Not the best things for a sensitive knock sensor but that car oddly with no tune freaking moves.
Thanks for the refferal on the work. Ib be glad to take it.
Old Dec 19, 2010 | 12:48 PM
  #78
tscompusa2's Avatar
crap you're right.. my bad i was getting him confused with another person. he has cosworth m3 cams 280/272. ya your timing is dead on, no worries man.. had him check it and he sent me pictures its 100%.
pm me info you want me to give to customers in your area for installations and ill give it to them and refer you to them.
Ya his cars a freak so far. 351/356 @ 23psi only on 9 turbo. i think we might crack 400 on 93oct with his car.. thats with only 8* timing uptop. he had 3 people in the car on this pull.
Old Dec 19, 2010 | 12:56 PM
  #79
n2oiroc's Avatar
i wouldnt go that far, but the difference between pb and wd40 is smaller than the difference between kroil and pb. its enough of a difference to make it worth buying. and 1 can will last as long as 2 cans of pb blaster. it goes a long way.
Old Dec 19, 2010 | 06:41 PM
  #80
EvoDan2004's Avatar
yea i loved that stuff when i had it. i didnt even let others borrow it. it was like liquid gold. haha.
Old Dec 21, 2010 | 08:39 PM
  #81
Geoff Raicer's Avatar
the OS is quieter then my QM was for sure. im just weary about it lasting or holding up to my abuse
OS Giken makes some of the strongest and best designed + most reliable parts in the world. They are legendary for their RB26 parts. I would not be concerned about your clutch - you shoulda taken my advice in the first place with that QM unit
btw - those BR rear diff mounts + mustache bar are sick!! i know of a rear subframe for sale - check your PM
Old Dec 22, 2010 | 09:48 AM
  #82
PATRICK B.'s Avatar
I'm actually still kinda stumped why poor Dan had such issues with the QM when plenty of other s have had better success even though it is not the most ideal clutch for street use...................Dan have you sent it back to QM or are you just completely "over it"
Old Dec 22, 2010 | 09:54 AM
  #83
EvoDan2004's Avatar
I have no idea what the deal was with it. I am done with it for now. If the OS burns up then maybe I will try there new version clutch. As for the one I had I gave it away to a friend.
Old Dec 22, 2010 | 10:13 AM
  #84
JohnBradley's Avatar
Our subframe has a broke bolt in it when I went to pull it this morning
Old Dec 22, 2010 | 10:53 AM
  #85
EvoDan2004's Avatar
ok thanks man. seems to be my luck.
i just placed an order with Russell M from mitsubishiparts.net and dropped 200 bucks on all new nuts, bolts, washers, and other stuff.
Old Dec 22, 2010 | 06:55 PM
  #86
EvoDan2004's Avatar
i got a rear sub frame on its way to my door. maybe now i can get the car back together again. thanks to the guys who helped me out and for checking if they had one or not.
Old Dec 22, 2010 | 07:55 PM
  #87
mayberry's Avatar
instead what i am going to do is weigh this part on a scale. and then im going to remove a lot of the factory casting marks and a bunch of stuff thats on it that does not need to be. i would like to see how light i can get it without loosing the integrity of the sub frame. call me crazy i guess.
No problem man. I'm really interested in seeing how that works out for you. I'd be interested in doing something like that.
Old Dec 27, 2010 | 08:20 AM
  #88
n2oiroc's Avatar
fyi, i followed the link above and got 2 13oz cans shipped to me for a total of $12. hell of a deal!
Old Dec 27, 2010 | 08:57 PM
  #89
CO_VR4's Avatar
Dan, if that happens again, (or if someone else is in the same problem) call around to a machine shop or tool and die shop until you find one with an EDM. They can disintegrate the broken bolt (or tap, or whatever you have stuck) without damaging the aluminium subframe.
Old Dec 28, 2010 | 07:41 AM
  #90
EvoDan2004's Avatar
thanks for the info bro.
