Buschur Racing Dual Stage Boost Controller
Old Nov 15, 2010 | 08:11 PM
dinok's Avatar
anyone have experience with the Buschur Racing Dual Stage Boost Controller
i have a 440whp setup right now on 25psi but im doing my twin disc setup in a few months and wanna have 2 different boost levels with a flick of the switch and not having to adjust the boost controller manually
i wanna have a 28psi setup with 475whp 410wtq
and another boost level for every day driving at 24psi 430whp probably
is this a good modification for what i need ?
Old Nov 15, 2010 | 08:21 PM
aka.ralliart15's Avatar
im gonna say no, unless the boost controller can switch maps for you....understand that just because you raise the boost it doesnt mean you'll make more power, or be safe for that matter since the map will probably hit different spots on that tune....so what you really need is ECU boost control, two maps, and either a laptop or a map-changing switch.
Old Nov 15, 2010 | 08:27 PM
Cracing's Avatar
I would say go with a dejon dual boost controller (much cheaper) and have an experienced tuner do the tephra mod on it so you can run two different maps at a switch of a button. This is useful for someone looking for a gas tune 91, 93 etc and a e85 or race gas tune. You can have both the map and boost switch with a flick of a switch. I am currently tuned on a 91 and e85 tune. This would be usefull for you with a high boost setting and low boost setting with corresponding maps.
n2oiroc's Avatar
i dont think he makes them anymore. get this: http://www.hallmanboostcontroller.co...ml#EvolutionRX its very easy to adjust on the fly. and if you arent changing fuels, then you dont need to change maps unless you have a really bad tune. if its tuned for 28 psi, then you can turn it down to 24 with zero issues.
Old Nov 15, 2010 | 08:52 PM
dinok's Avatar
i wanted to get 2 different maps put on the 2 different boost levels !
i just dont want to MANUALLY adjust the boost
there HAS TO BE a way this is done loll
Old Nov 15, 2010 | 08:54 PM
dinok's Avatar
i have a hallman PRO rx boost controller i want to ELIMINATE THE MANUAL BOOST CONTROLLING
i want 2 alternative maps on different boost levels !!
ive seen it done just want to do it the correct way and this kit looks perfect for it !!
Old Nov 15, 2010 | 11:18 PM
Cracing's Avatar
http://all.dejonpowerhouse.com/edit/A-03.htm
Old Nov 20, 2010 | 01:25 PM
3bar_dc2's Avatar
You can use ecu boost control with a mac valve or grimmspeed ebc and pick up a map switching harness here ---> http://www.mellontuning.com/index.ph...8be6132fd74b36
Old Nov 20, 2010 | 02:40 PM
EVO IXMR's Avatar
Exactly what I was thinking or a ebc...
Old Nov 20, 2010 | 02:42 PM
EVO IXMR's Avatar
Actually he can tune the car for 27 psi and then drop the boost down to 23 psi which is fine the only thing it might be a bit rich but safe..
David Buschur
33
Jun 16, 2012 06:04 AM
AWD Motorsports
136
Sep 19, 2011 06:29 PM
Gazika
Dec 21, 2009 06:01 AM
boosted hybrid
10
Feb 24, 2008 11:47 AM
