what's the best oil for race engine?
Old Nov 20, 2010 | 04:14 PM
Kracka's Avatar
Look up the actual spec sheets for the oils you're interested in rather than relying on internet hearsay and discuss it with your engine builder.
Old Nov 20, 2010 | 04:15 PM
EVO(boss)'s Avatar
Originally Posted by JC evo1
I would not use magnatec in a hi performance motor. Mobil 1 15w 50 is probably the best choice from what you listed. Rotella 5w 40 would be next best.
in fact we have Mobil 1 20w-50 also we have castrol Sport 10W-60 synthetic so i don't know which one better for my 2.3L engine
Old Nov 20, 2010 | 04:17 PM
EmeryatSTM's Avatar
Originally Posted by Supraboy1
I am curious why so many seem to be pushing thicker weight oils in small engines with light weight internals. The EVO engines are similar in rotation mass as are formula one engines and they use a 0-30 weight and even a 0-20 weights oils. Im not an oil expert but its my understanding from my boat racing experience...( 502 ci engines making 1000 hp ) thats when you want to run a 50 weight oil for all the heavy parts. If someone knows for sure different from a real technical standpoint please speak out.
Its pretty easy answer. In fact, you kinda answered it your self. Remember the compression stroke carries a lot of "weight" down on the bearings. You have big v8 engines making 125hp per cylinder. We have little 4 cylinder motors making 200 hp per piston. No matter what way you cut it up, that is a lot of pressure on the rotating parts and the heavier oil protects that much more.
-Em
Old Nov 20, 2010 | 04:27 PM
Ted B's Avatar
We can't realistically equate 4G63s to F1 engines. F1 engines are designed from the ground up to use lightweight oils, and aren't expected to go 100k miles between rebuilds.
The use of higher viscosity oils in small displacement, high revving engines seems to be a continuation of an age-old preventative measure against viscosity loss due to high temperatures and shear. Full synthetics provide superior protection against issues, so this isn't as important as it was in years past (not to users of full synthetics anyway).
One thing that I've noted over past years with 4G63s is how those who take them out and really beat on them at the drags claim the thicker film of 40-50 weight oils fared better where oil pump longevity is concerned. I have no way to prove or disprove this, nor do I feel it's applicable to most here. Ultimately, it may be more so a matter of film strength than thickness, but again, I have no way to prove this.
Under no circumstances should you consider the 60 weight oil. Even M1 20w-50 is on the heavy side. Check into the M1 10w-40 4T oil I suggested above.
Old Nov 20, 2010 | 04:52 PM
EVO(boss)'s Avatar
ok i will check if we have a M1 10w-40 4T then if we don't have what would be the second choice?
Old Nov 20, 2010 | 08:52 PM
sparky's Avatar
Can you get Motul 300V Racing oil? If so, you might want to look into either the 10W-40 Chrono, or the 15W-50 Competition. Both feature a double ester formulation with 0% shear. They are however relatively expensive. But cost isn´t an impediment is it when seeking quality?
Old Nov 22, 2010 | 10:30 AM
3bar_dc2's Avatar
I prefer M1 0w-40 to Shell Rotella T6 5w-40 where readily available 40 weight oils are concerned, primarily because the Shell product's literature specifically claims it to be formulated with minimal phosphorus content. While that doesn't appear to present issues in most cases, I can't see anything about it that makes it especially desirable, not on paper anyway.
Good to know.
Old Nov 22, 2010 | 07:26 PM
JC evo1's Avatar
Rotella T6 5w 40 voa http://home.earthlink.net/~alan.m.ro...lla5W-40T6.jpg
Old Nov 22, 2010 | 09:45 PM
norcalSRTrida's Avatar
thanks for sharing.
that is the oil i run in my car (Shell Rotella 5w-40). i get it by the jug for 24$ at my local autozone.
Old Dec 30, 2010 | 06:59 PM
BoostedAWD25's Avatar
Rotella t6 5w40 it's API certified SM so it's fine to use , they just market this oil more for the truck industry being they have this market tied up pretty good. they don't call it million mile oil for nothing, this oil withstands 35+ psi of boost and 18:1 compression ratio just imagine the stress thats put on the bearings.
Read the full details here this oil is awesome im running it in my 4g63 as we speak for winter time= http://www-static.shell.com/static/c...rotella_t6.pdf
Old Dec 30, 2010 | 07:08 PM
sonicnofadz's Avatar
Please read this:
http://store.forcedperformance.net/m...otor%20Oil.pdf
Old Dec 30, 2010 | 07:34 PM
wht95scort's Avatar
Is it safe to run the brad penn 20-50 oil in a stock engine?
Old Dec 30, 2010 | 07:49 PM
No point in doing that your not making krazy power or tracking the car that oil is aimed more for built motors,track cars,and highly modified cars. Brad Penn even states that on there website its for high performance engines. You can run brad pen 10w-30 as its for street/track cars or Run 10w-40 or 15w-50 if you plan on beating on it in summer time cause of more heat protection but in winter 10w-30 is fine or 5w-40.
Old Dec 30, 2010 | 08:00 PM
boostedtres's Avatar
this thread has a lot of good information on oil weights, keep the posts coming.
my one concern, away from the oil debate, is that if you have a person essentially building you evo engine from the ground up, they should be able to TELL YOU the proper oil to be used. if they suggest asking people on forums or online, that (for me at least) would be a red flag as far as a 4g63 engine builder is concerned.
obviously if he/she has a track record of building good engines, thats awesome. but if he cant recommend a good oil for it to run on....hmmm i duno. just my thoughts.
gl with your choice! cheers
Old Dec 30, 2010 | 08:47 PM
talonesi95t's Avatar
since i bought my evo ive used mobile one 10w-30 but reading here guess ill have to look for something better to use
JVBEvo5
16
Aug 25, 2017 07:51 AM
Luan Nguyen
Oct 30, 2016 03:26 PM
fjm9898
Mar 20, 2013 04:21 PM
09Ralli
29
Mar 5, 2013 07:19 AM
hatakashi
Aug 12, 2011 06:27 AM
