late spool on a 50 trim (help)
Old Nov 28, 2010 | 06:31 PM
  #31
t1mike's Avatar
Originally Posted by 03evilution
to be honest it was on the car when i bought it so i dont know
I would find out if possible. This can have a huge effect on response time. The tune can also have a large effect .
Old Nov 28, 2010 | 07:39 PM
  #32
cij911's Avatar
Tom - AFRs fluctuate 0.5 pts from just 15 degrees? I'm in socal and generally don't see more than 30 degree fluctuation year round, but I don't think my AFRs change that much. I guess i need to do some more logging.
Also, may I ask your opinion on fast spool- I have seen two paths run rich and run lean. Which do you like to do ? I think my spool up could be better optimized. TIA
Old Nov 28, 2010 | 07:50 PM
  #33
sparky's Avatar
tscompusa, sorry for the OT, but which upgraded FMIC did you decide to go with
Old Nov 28, 2010 | 07:51 PM
  #34
tscompusa2's Avatar
Buschur Race Garrett 3.8" core. Fitments a little tight, but great FMIC.
https://www.evolutionm.net/forums/8541351-post73.html
and go here for more related tuning talk https://www.evolutionm.net/forums/ev...k-39psi-6.html
Old Nov 28, 2010 | 07:58 PM
  #35
EVO IXMR's Avatar
Who's was even talking about e85.. I was talking about pump funny how you change your story around now..This guy on this thread is on pump so am I and cij911 is on pump and meth.I said the most .4 and you hate when people miss inform others..Anyways your the tuner with 6 years of tuning right,.
Old Nov 28, 2010 | 08:26 PM
  #36
cij911's Avatar
Tom - Thanks for the advice. I just did my first log in a long time today and I will look at it and get your thoughts. I think I am 85% there with my tune - just need to tweak the partial boost areas and see if I can improve the tip in / spool up area.
I know what I really need is to get cams and possibly a better FMIC. Thanks again!
Old Nov 28, 2010 | 08:46 PM
  #37
tscompusa2's Avatar
no problem, but honestly i think the ETS 3.5" is fine for a FP green. If not contact ETS and get the 3.8" garrett core they sell.
Old Nov 29, 2010 | 05:51 AM
  #38
cij911's Avatar
Well I logged my car yesterday and I am definitely too rich from ~3300 to 4500 (currently 11.5 to 10.8 vs. more like what I should be 12 or 12.5). It will be interesting to see if changing the AFRs ~0.5 pts or so really helps my spool up (other areas seem to be spot on) - post 4500 rpm 11.5 AFR solid.
Old Nov 29, 2010 | 06:36 AM
  #39
03evilution's Avatar
From: Poughkeepsie NY, Central Jersey Shore, Fort Meade MD
Originally Posted by cij911
The Ecuflash sub-forum is free to read ...Just search Tephra patch or v7 and you'll find a bunch of useful information....
so i read a few forums on the tephramod v7...is this a do it yourself program u put on your computer or a program alot of dynotuners use? seems like it does quite alot on a stock ecu. is this a good route or would an aem ems be better for those who have the money to upgrade?
Old Nov 29, 2010 | 07:10 AM
  #40
cij911's Avatar
Well I really think it depends on what you are looking to do with your car. In California you need to keep the factory ECU for emissions purposes and I'd imagine the same is true for NY (but no idea). I also think the factory ECU is completely fine for 99% of cars out there - there are a number of 600hp+ cars on the factory ECU.
Old Nov 29, 2010 | 07:22 AM
  #41
the emissions in ny arent as bad as cali...i believe they more so just look for engine lights and such. now is this a more DIY programing or something alot of shops use?
Old Nov 29, 2010 | 08:10 AM
  #42
cij911's Avatar
This (Ecuflash) is NOT just a DIY thing...Ecuflash has been used since 2006 to flash Evo ECUs and most (if not all) of the professional tuners have embraced it and use it daily to tune cars...If you find a tuner that says that don't use it, move on to someone else...
Old Nov 29, 2010 | 08:37 AM
  #43
tscompusa2's Avatar
ya, pretty common occurance as I stated before. It needs retuned to spool faster in this weather. and yes, it will make a world of difference. Theres also a wrong and a right way to tune for spoolup, but im not getting into that on here.
Old Nov 29, 2010 | 08:58 AM
  #44
k sounds good man...being that im so close to him im probably going to have dynoflash al tune my car
Old Nov 29, 2010 | 09:13 AM
  #45
cij911's Avatar
Hmmmm....there are a lot of choices...you may want to do some research before you decide...
