Oil surge on drag launch
Old Dec 5, 2010 | 04:25 PM
miragevo's Avatar
Veteran: Navy
I've been gathering parts for a while now and bought one of these Tomei slicing baffles and plan on putting in my 4G63. But I have been toying with building a LR2.4 with the 100mm crank and I feel confident that I could modify it to fit with spacers and or a dremel tool. It's cheap enough to purchase and check into it...it just may be worth it.
Old Dec 5, 2010 | 04:44 PM
EmeryatSTM's Avatar
I have never tested anything back to back but we run about a half quart extra in our cars while racing. It helps with the launch and the back end of the track while the head is full of oil.
-Em
Old Dec 5, 2010 | 04:52 PM
miragevo's Avatar
Veteran: Navy
I wonder if David has done his oil pan mods on the 2.4L pan yet? He's built quite a few 2.4's now; maybe he can chime in.
Old Dec 5, 2010 | 04:56 PM
David Buschur's Avatar
We use the 4g63 pan on the 4g64 block and yes our sump mod works on it too.
Old Dec 5, 2010 | 05:06 PM
miragevo's Avatar
Veteran: Navy
I wasn't sure if the 4G63 oil pan fit the 4G64 with 100mm crank.....Awesome to know! I'll keep you in mind for my up coming spring build. Thanks
Old Dec 5, 2010 | 06:23 PM
03whitegsr's Avatar
Just something worth noting, your oil temp was 25C higher on the first run.
It might not be the main difference, but I bet it isn't helping.
I like the idea of an accusump, but I don't like the idea of the extra weight and if you can get solid oil control with just some tweaks to the pickup/pan and things like Kiggly's regulator, I'd rather go that route.
Old Dec 5, 2010 | 06:55 PM
RSMike's Avatar
Ah... good spotting. I hadn't actually looked at that, i just checked the oil pressure.
I already have the kiggly regulator in the head.
I'm thinking that with a good oil pan i should be able to solve the problem, i'm just wondering if a modified oil pan will work for track work too.
At the end of the day, an accusump is a band aid to a problem that is already there. I should really fix it rather than covering it up
Cheers, Mike
Randal
47
Aug 31, 2012 08:23 AM
5LEEPERISAH23I
Dec 27, 2010 03:18 PM
Joe's Evo X
Jul 10, 2009 04:22 PM
Trbo Dad
14
Dec 14, 2003 02:10 PM
ace33joe
Sep 5, 2003 04:03 PM
