After Cam install.. some ticking noise.
Old Dec 19, 2010 | 07:10 AM
The Storm's Avatar
I just put in gsc s1's and did not bleed the lifters, no tick at all.
Old Dec 19, 2010 | 07:38 AM
erald01's Avatar
i dont understand everyone that says BLEED THE LIFTERS, BLEED THE LIFTERS, no you dont need to bleed the lifters, because when the car is not running the lifters are dry anyways, the only time they have oil is when car is running. Lifters are designed to bleed on their own, and are supposed to have no oil in them when there is zero oil pressure. you ever noticed how loud they are when you first start your car?? thats because they are empty, and once oil reaches all the way to the head then the tickin stops. plus 4g63 engines are known to have noise lifters anyway. I have changed many sets of cams on evos and dsms and never had the problem of lifter noise.
Old Dec 19, 2010 | 07:39 AM
erald01's Avatar
point proven
Old Dec 19, 2010 | 07:47 AM
miragevo's Avatar
Veteran: Navy
Originally Posted by Brsox10288
Also when i took a sharp right turn the car made a louder tapping noise that came from the engine.
Check your oil level.
Old Dec 19, 2010 | 08:13 AM
Brsox10288's Avatar
Thanks for the comment but i already figured out the problem as stated in my post.
Ichigo0Soul
21
Mar 26, 2014 05:43 AM
mattsgto
Apr 11, 2010 11:04 PM
aceinthesky2002
14
Feb 20, 2008 10:27 AM
jrsimon27
24
Mar 27, 2007 04:04 AM
WADADLIG_OZ
Lancer Engine Tech
52
Nov 11, 2005 04:57 AM
