Turbo oil supply from block
Old Dec 17, 2010 | 04:19 PM
okevolutionVIII's Avatar
Due to a stripped out thread on my cylinder head for the oil feed line, I've blocked off the hole and I'm now trying a different route. I now have a SS -4AN line from the turbo to a tee between the block and oil pressure sensor. My question is will that provide enough pressure to the turbo? Too much to where I'd need a filter/restrictor in-line? This is on a IX turbo.
Old Dec 18, 2010 | 07:57 AM
Up
Old Dec 19, 2010 | 01:55 PM
Does anyone know what psi of oil pressure to the turbo I should be aiming for at least????
Old Dec 19, 2010 | 04:11 PM
The-Evo's Avatar
Iam having the same question? I reciently sold my fp black and I still have the fp oil feed line feeding a stock evo 9 turbo. If anyone knows, will this be okay to used the same fp oil line instead of the stock line from the head.
Old Dec 19, 2010 | 04:15 PM
tscompusa2's Avatar
running it from the oil filter housing is better then the head...... the oil cleaner and okevolutionVIII i think it will be ok where you have it feeding from but would be better from the oil filter housing.
Old Dec 19, 2010 | 06:50 PM
BuiltS13's Avatar
Oil filter housing is the best place, not only because its cleaner but the pressure at the oil filter housing is better for the turbo.
Old Dec 19, 2010 | 09:14 PM
I plan on running it that way in the future, I'm just trying to get the car running and will not be pushing it hard for a while. I've seen a lot of Hondas run the line off the block but never seen/heard of this done on a 4G63. I just want to make sure there's enough pressure.
honda-guy
28
Jan 30, 2021 08:48 PM
Evo__Lee
Sep 18, 2016 09:39 PM
Biggy VIII
Aug 9, 2016 03:06 PM
selp
Jul 5, 2014 04:37 PM
dirtylilevo
11
Apr 4, 2013 12:00 AM
