pulling driver's axle from 6 speed trans (WTF?)
Old Dec 23, 2010 | 04:20 PM
Steve_P's Avatar
I have a 2006 MR, 6 spd, with a leaking driver's side trans to axle oil seal. I have everything out (axle free from hub) and cannot get the axle to pop out of the transmission. I am using a pry bar between the inner CV housing and the trans housing and it will NOT budge. I've pulled axles multiple times from different cars and never had a problem like this.
Am I missing something here? Do I need to remove something else (magic retainer bolt?) to get the axle out, or do I just need to have some Wheaties for breakfast and have at it again???
Old Dec 23, 2010 | 04:29 PM
milruner's Avatar
no magic hidden bolt maybe your C clip on the end of the axle is just stuck, and making you fight it. Try doing even pressure pry by using 2 pry bars, or 2 really big flathead screwdriver to pop it loose. using them on opposite sides of each other that is.
MIKE
Old Dec 24, 2010 | 09:49 AM
Steve_P's Avatar
thanks, pretty much as I figured. Dunno why this is giving me such a hard time; I'll take another go at it here in a bit. The axle will move at the trans ~3 mm if i push it in and pry it out, so it's definitely not totally seized in place.
Old Dec 24, 2010 | 09:54 AM
turbolarry's Avatar
I did mine a while back and I think I ended up having to smack the pry bar with a dead blow hammer. Go to step 25;
http://www.evomoto.com/tech_articles..._article_id=27
Old Dec 24, 2010 | 09:58 AM
_mcjonnyp's Avatar
use a bigger hammer
Old Dec 24, 2010 | 06:12 PM
Steve_P's Avatar
I managed to get it out on the second go-round. I used a pry bar that I could strike on and put a small steel plate on the trans case to pry against. The HF pry bars with the plastic handles just wouldn't do it this time although that's what I've always used before.
I used something like this and struck the side of the pointy end with a hammer.
http://www.amazon.com/OTC-7166-Long-...243015&sr=8-33
The cross shaft also came out of the transmission but I got that removed from the axle with no trouble and will put it back in. Unfortunately, I received the wrong oil seal from mitsuparts.net so the car will sit on jackstands for a while until I can get the right part. Bummer.
Old Dec 24, 2010 | 06:19 PM
tscompusa2's Avatar
ya you just give it a quick jerk and they pop right out. glad you got it out. no need to remove shaft from axle but doesnt hurt either.
your car was def worked on before if the shaft came out with the axle.
Old Dec 24, 2010 | 07:03 PM
azinterrider's Avatar
LOL Mis read
Old Dec 24, 2010 | 07:42 PM
tscompusa2's Avatar
Originally Posted by azinterrider
Dent puller with a screw welded to the end makes simple work of these tasks. Invest in one and no risk of damage from pry bars.
i take it you never pulled an axle out before after saying something like that
he had trouble pulling an AXLE out not an output shaft.
Old Dec 24, 2010 | 10:13 PM
turbotalawd's Avatar
Glad you got it out. Sometimes it helps to rotate the axle a bit to give the c-clip a different orientation then try prying on it.
Old Dec 24, 2010 | 11:35 PM
ROFL I misread it there buddy. Lets not get in to a battle of IQ's here!
Old Dec 25, 2010 | 02:44 PM
Steve_P's Avatar
no, it has never been apart before this; I bought it new. taking the shaft out makes it easier to install the axle as I have the hub still attached to the strut.
Since it was up in the air I spent xmas afternoon changing brake fluid out
jhoganusaf
Jan 28, 2014 09:25 PM
brunz44
Aug 29, 2013 07:32 PM
volkevo9
Oct 22, 2011 07:36 PM
Sti THIS
Feb 24, 2010 03:20 PM
03TTCobraSVT
Jul 27, 2009 05:39 PM
