apexi intake and now p0234 (engine overboost)
Old Dec 31, 2010 | 07:49 AM
ilikeboost's Avatar
So I installed the intake and induction box. I'm taking it out for a drive, and 4th gear wot into fifth I hear a bang, like a misfire. The cel comes on and its a p0234 eng overboost. The only mods I have are turboback exhaust and invidia test pipe w cel fix. What could cause this issue? I searched and didn't really find anything. I know I'm gonna need a tune but is this normal? Maybe another issue? And did I hurt my car?
Old Dec 31, 2010 | 07:59 AM
nytalonTSi's Avatar
That code will always come up, you clear it and it shouldn't come back on. But unless you get a tune the code will turn on and you will get that bang when going WOT.
You don't have a tune right? A tuner can make the tweak to fix it.
Old Dec 31, 2010 | 10:46 AM
ilikeboost's Avatar
No tune yet. They are closed for the holidays. So why is it doing it? Not enough fuel to handle the new air?
Old Dec 31, 2010 | 10:51 AM
Rafael2109's Avatar
Maybe the car is overboosting and the OEM ECU do a boost cut, it is easy to do, but it is needed to do, until you get the tune do some wot starting at high rpm to not produce this much of boost.
Old Dec 31, 2010 | 11:51 AM
sirsol's Avatar
Did you mess with the vac. lines off the W/G actuator at all? If that became disconnected or damaged, you can lose your vac. signal to the WG and overboost.
Hook up a manual boost gauge and see what PSI your hitting. Also, double check your install to be safe.
Old Dec 31, 2010 | 01:23 PM
ilikeboost's Avatar
I didn't touch the vac lines, I hold GD vacuum, at wot I spike to 1.5 bar or 21 psi ish. Is this life threatening to my motor. I am worried it happened twice and now I'm baby ing it til I get a tune
Old Dec 31, 2010 | 01:58 PM
raasfaas's Avatar
Yea it sounds like you're hitting boost cut...looks like the intake upgrade is now making you hit higher loads. As a bandaid until you can get a retune or have your boosy cut limit raised...just lower the boost a couple lbs which will in turn lower the load the car see's.
Nick919
14
Aug 26, 2017 11:06 AM
McDougal
Jun 15, 2007 11:59 AM
smp3000
Nov 23, 2005 11:07 AM
SlowCar
Aug 14, 2005 05:11 PM
bigjhoney
Mar 7, 2005 06:38 AM
