New BW EFR Turbo Thread
Old Feb 23, 2012 | 10:55 PM
  #1531
WhoAmI181's Avatar
Guys, finally fixed up the EFR8374 (non-WG 1.04TS), which was received last Dec...
EFR8374
Got the car fairly tuned up to just 1.8bar because engine seems to be losing compression after 6500rpm. Could be leakage from the gasket.. So decided to halt the dyno and get it fix first.
Nevertheless, the efr turbo is simply stunning! Here's the dyno graphs:
Too many lines BUT just focus on the PINK and BLACK.
PINK line - EFR8374 with pump gas 93 octane @ 1.8bar - 618hp, 70Kg.m.
BLACK line - GT35 with C16 @ 2bar - 652hp, 70Kg.m.
Both done on the SAME engine and dyno -> rollers like Mustang Dyno (not Dynopack type)
All I can say is..... VERY IMPRESSIVE!!!!!! 618hp/70kg.m on pump gas @ 1.8bar... These figures almost match those on C16 with higher boost...!
I am EXTREMELY HAPPY with the turbo... It has achieved my initial requirements when I ordered this turbo..... Its going to be a crazy b*tch on track when C16 comes in... Based on past experience, C16 produces at least 100hp gain... And I believe once we solve the compression problem, more hp and torque will be produced even at current boost level...
Special thanks to Geoff for his advice during our installation!
Old Feb 24, 2012 | 10:10 AM
  #1532
n2oiroc's Avatar
So 618 whp on 93 at 26 psi?
Old Feb 24, 2012 | 01:16 PM
  #1533
kutija's Avatar
was gt35r also twin scroll or single scroll?
Old Feb 24, 2012 | 07:12 PM
  #1534
batty200's Avatar
What is the cost of the EFR kit with IWG and EWG? Just trying to get a cost/benefit vs a std kit like AMS/ETS HTA86/6262 combos.
Old Feb 25, 2012 | 11:00 PM
  #1535
WhoAmI181's Avatar
Engine, 93octane pump gas @ approx. 1.76bar..
Old Feb 25, 2012 | 11:02 PM
  #1536
WhoAmI181's Avatar
Old school single scroll.. running advanced timings with C16
Old Feb 25, 2012 | 11:03 PM
  #1537
WhoAmI181's Avatar
Hmm.. probably Geoff can gives a better cost breakdown for you..
Old Feb 26, 2012 | 12:22 AM
  #1538
RSMike's Avatar
so your twin scroll EFR spools slower than an open scroll GT35?
Old Feb 26, 2012 | 12:50 AM
  #1539
SDevo13's Avatar
Guessing the 35 was a non-hta?
Old Feb 26, 2012 | 02:59 AM
  #1540
user 72082032's Avatar
Hardly a fair comparison yet is it! C16 high boost 35 vs pump gas with low boost EFR. Even if you were to be conservative and add 30bhp all the way through it would smoke the GT35 everywhere.
Old Feb 26, 2012 | 11:12 AM
  #1541
deeman101's Avatar
I'm going to assume the race gas with the 35r allowed him to tune more aggressively and gain more torque lower down. Still the difference doesn't seem that big.
Old Feb 26, 2012 | 03:08 PM
  #1542
03whitegsr's Avatar
28psi vs. 26 psi isn't exactly "high boost" vs. "low boost."
All I see is the EFR on 93 octane slightly more power at a given boost level but the 35R on C16 making 30 more HP with 2 more pounds of boost. Spool on the dyno looks to be the same.
Different boost or not, that's the only way you can really look at that chart as anything else is speculation.
Old Feb 26, 2012 | 03:17 PM
  #1543
batty200's Avatar
That EFR looks like it is running out of steam. The power is nosing over at a lower peak power and boost level. I wouldnt expect to see a better powerband at higher boost since clearly the EFR is already running into some sort of wall. On my cars whenever the turbo is tapping out it looks worse as the boost gets higher because it peaks faster and then falls off faster. Hopefully you get it sorted out and do 2bar on c16 and do a direct comparison.
Old Feb 26, 2012 | 03:20 PM
  #1544
batty200's Avatar
How much was your kit? That will give us an idea since we all know what an HTA86 kit costs from various vendors.
Old Feb 26, 2012 | 04:34 PM
  #1545
MrLith's Avatar
I'd taken note of that too, but am pretty convinced the EFR8374 will outflow a GT3582R - I'd say (or hope) the issue is more boost tailing off like a lot of the EFR setups seem to do, due to boost control as opposed to flow. Thats what I am hoping is the case, at least - would be ridiculous if it can't match the old GT35R!
