hard to get into gear when cold, clutch adjustment or fluid?
Old Feb 16, 2011 | 07:45 PM
  #31
mishimevo8's Avatar
Well i just got my evo and was having the cold shift problem and installed my 6 puck 3 weeks after i got the car and no more problems for me. Works great . Id deffinetely upgrade the clutch and go with a gl4 fluid, Gl5 is a not yellow metal friendly!
Old Feb 16, 2011 | 07:52 PM
  #32
tsidrift1's Avatar
Ever since my car has sat in a garage overnight, I dont have the problem. The car already has an exedy twin in it. I am gonna be adjusting the clutch fri, along with bleeding the system.
Old Feb 16, 2011 | 08:01 PM
  #33
alwaysboostin's Avatar
Its your fluid it's to thick for cold weather I had the same prob changed it with different fluid it's good now
Old Feb 16, 2011 | 08:17 PM
  #34
MitsuJDM's Avatar
Could be the fluid, but sounds like the clutch is dragging. May be a faulty clutch or like others said, bleed the slave cylinder. Changing both the fluid and bleeding the slave are simple. Get those two out of the way before jumping to conclusions.
If the car lurches forward when you put it into gear or force it into gear, the clutch IS dragging, and there could be multiple reasons as to why. Air in slave cylinder, clutch fork is worn, faulty clutch, etc.
My car does this as well. I notice it more in the cold, but still does it on occasion when it's warm. I've been using AMSoil for 10k miles, but switching to something else in 5000 miles. Alos going to bleed the slave and see if it helps. I've driven many cars other than Evo's, that have a slight lurch forward when placing into first gear. Seems almost common for a car with an aftermarket clutch to do this.
Old Feb 17, 2011 | 07:02 AM
  #35
barneyb's Avatar
Clutch drags when cold but okay when hot - clutch slightly out of adjustment. Car wants to go forward in neutral when extremely cold - thick gear oil.
Old Feb 17, 2011 | 10:05 PM
  #36
Pirana's Avatar
ok, found this on lancershop.com. does it really work? seems to be a common problem on aftermarket clutches.
"When running clutches like the Exedy Single, Dual, and Triple Clutch Kits. Problems have been known to exist; due to clutch not fully disengaging.
With this machined clutch extender rod, your clutch will properly work. Save your transmission, and save your synchros.
Machined from strong 4140 chromium-molybdenum steel (not some weak mild steel from a local hardware store) and built 1/4" shorter than stock, this modified clutch slave cylinder rod will give you a plenty of clutch adjustment range without maxing out.
A recommended upgrade when replacing or rebuilding the clutch slave cylinder on EVO with heavy clutch kits.
Fits Lancer Evolution VIII / IX "
Old Jan 21, 2014 | 07:57 AM
  #37
EVOREZ1992's Avatar
Originally Posted by Kracka
Quite a bolt statement when you obviously can't prove that from across the internet. If it is the clutch dragging then a simple adjustment of raising the engagement could cure that. It is also very possible he's running too thick of a transmission fluid for the winter cold such as a GL-4 75W-90.
Sorry to get involved but what does it mean that the clutch is dragging?
Old Jan 30, 2014 | 09:59 PM
  #38
troy_ix's Avatar
i know this thread is a couple years old now, but im having this problem in australia with my ix. Exedy twin plate clutch parked in garage and is still hard to get reverse until its warm. Anyone have a solution to fix this
Old Jan 30, 2014 | 10:13 PM
  #39
S.Brewer's Avatar
FCOTM Winner
Mine was being a little pain in the same way. I just adjusted my clutch pedal out. Didn't want to do it too much because I want to be in spec for operating temp. Worked for me
Old Feb 4, 2014 | 05:15 AM
  #40
viii u's Avatar
mines in the garage and still does has the same problem ill probably have to change the fluid and see how it goes at the moment. I have the oem fluid might go with Amsoil.
2slowEVO8
Sep 19, 2021 02:14 PM
mrmiller
Jun 21, 2016 07:08 PM
CaptainSquirts
May 17, 2016 08:35 PM
Ghost1t
Jun 17, 2013 12:54 PM
nytalonTSi
Jul 27, 2011 10:26 AM
