FPGreen external waste gate
Old Jan 16, 2011 | 08:23 AM
Steven's Avatar
Are you getting boost creep or boost spike? Is it hitting more than 20 psi then backing down or holding 20 psi then creeping upwards. 20 psi is really low for an FP green. I think my IX was pushing 22 from the factory. Why are you trying to set the boost so low?
Old Jan 16, 2011 | 05:42 PM
balleronabudget's Avatar
I don't exactly know which WGA I have. It was on the car when I bought it. The car is tuned for 20 psi however it will not stop there. In first and second gears on a hard pull, boost goes right to 20 psi and holds. On longer gears like third it hits 20 and keeps climbing. I'm getting tired of dealing with this problem so assumed an EWG would do the trick. I don't know what a WGA turnbuckle is, and I don't mean to sound retarded, but answers will have to broken down Barney style.
Old Jan 16, 2011 | 06:32 PM
KX250Fmotoracer's Avatar
The turnbuckle is the long threaded adjustment rod on the actuator.
How much higher is boost going? Higher gears will boost higher, as there is more load on the engine.
20psi is nothing on these cars. IIRC thats stock!
Old Jan 16, 2011 | 06:59 PM
sparky's Avatar
Originally Posted by batty200
If you are going to add meth injection there is less reason to go EWG.....
Batty makes sense here. If you are going to run pump/meth then you'll be able to run 30# of boost. So, you can set boost at 23# and creep up to 30# with no problem on the stock internal gate.
Old Jan 16, 2011 | 11:41 PM
snazzyseth's Avatar
Originally Posted by balleronabudget
Thanks I appreciate it man.
just a fyi if you purchase this you need to weld the flapper open.
Old Jan 17, 2011 | 09:16 AM
Yeah I know. Already have a shop in mind to do it.
Old Jan 17, 2011 | 11:45 AM
BLKCarbonEVO's Avatar
Well currently right now my car is getting an external 44mm put on it. Should be at the dyno later today. I'll let you know how it does. I have a dump but I'm doing the external to try and hold more boost out the top.
Mikey
Old Jan 18, 2011 | 12:52 AM
RevMoto's Avatar
here is mine for reference.
Old Jan 23, 2011 | 06:29 AM
madiewaters's Avatar
do you weld the flapper open or
removed the flapper window and driled cause the got 2 hole there..
me just want to know and how the results...
im newbie here...
Old Jan 23, 2011 | 12:08 PM
im newbie here...
Well I can tell my looking at the pic that Spark removed the flapper and more than likely enlarged the holes a bit to allow the exhaust gases to flow better to the external allowing the external to be very efficient at controlling boost.
Spark, now you just need a 3" o2 housing!
Mikey
Dallas J
293
Oct 9, 2015 11:23 AM
audiofan
Oct 21, 2013 04:06 PM
dudical26
122
Jun 12, 2012 05:57 AM
JRR
16
Jan 10, 2010 08:15 PM
Ekoy
36
Dec 17, 2009 01:49 PM
